Alt 25.04.2003, 14:53   #1
Standard Synchronisieren V12 M70 Motronic Steuergeraete
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) nach Ausbau/-tausch
Alt 01.08.2010, 16:07   #2
hier noch mal geschrieben, bevor der Link mal verschwinden sollte:
Synchronisation of banks of M70 engine cylinders
The following information is important when replacing the Motronic control units or the EML control unit.
Each control unit is programmed with certain basic values, which are only mean values.
A control unit receives various input values depending on engine load conditions and compares them with the stored values.
An adaptive system compares the input values with stored curve family values, after which corresponding orders are put out to the concerned control elements.
If, for example, the EML control unit were without current for a long period of time (more than 1 hour), its adaptive system would lose the stored values.
The adaptive system would have to read in and store the input values of a certain engine after restoring operation of an erased control unit or installing a new control unit.
This procedure could lead to erratic idling of the engine after starting and disturbances in overrun.
Consequently there must be conformance with the following procedures before an EML control unit is replaced or after restoring operation of a disconnected control unit.
-run engine to operating temperature.
install (new) control unit and drive car. During test drive have the car coast three times from speeds above 5000 RPM to the idling range in transmission range 1 (approx. 10 seconds).
-Have engine run at idle speed in transmission range P or N at least 5 minutes!
These measures serve immediate and precise synchronisation of both banks of cylinders in all operating conditions.
Alt 03.02.2011, 12:14   #3
Hier noch einmal die Anleitung fuer den M70 V12 Motor in Deutsch, wo die beiden Drosselklappen nach dem Reset synchronisiert werden muessen:
Synchronisation der Zylinderbaenke des M70 (beide Drosselklappen)
Die Leerlaufdrehzahl ist in diesem Fall vom EML Steuergeraet elektronisch geregelt ueber die Drosselklappenmotoren.
Jedes Steuergeraet ist ab Werk mit gewissen Basiswerten programmiert, die nur circa Nennwerte sind.
Ein Steuergeraet empfaengt diverse Eingangswerte abhaengig von den Belastungszustaenden des Motors und vergleicht diese Werte mit den original einprogrammierten Werten.
Ein adaptives System vergleicht die Eingangswerte mit den einprogrammierten Werten, danach werden entsprechende "Befehle" an die Steuerelemente gegeben.
Falls zum Beispiel das EML Steuergeraet fuer eine gewisse Zeit (mehr als eine Stunde) ohne Strom ist, verliert das adaptive System die angelernten Werte und geht wieder auf die Basiswerte zurueck.
Das adaptive System muss wieder die (angelernten) Werte lesen durch die Inputs und speichert die angelernten Werte wieder neu nach einer gewissen Zeit.
Waehrend dieser Zeit koennte es unter Umstaenden zu einem unruhigen Motorlauf kommen, speziell im Leerlauf nach dem Neustart und Stoerungen ueber den Drehzahlbereich.
Deshalb sollte wie folgt vorgegangen werden, wenn das EML Steuergeraet ersetzt wird oder wenn das EML Steuergeraet fuer eine gewisse Zeit stromlos war:
-Motor starten und laufen lassen bis Betriebstemperatur erreicht ist.
Auto fahren. Waehrend dieser Phase sollte man drei Mal vom Drehzahlbereich ueber 5000 UPM runterkommen auf Leerlaufdrehzahl.
Dies sollte in Automatikstufe 1 gemacht werden (circa 10 Sekunden)
-danach Motor im Leerlauf in Getriebe-Stellung P oder N wenigstens 5 Minuten laufen lassen!
Hiermit wird errreicht, dass es eine sofortige Synchronisation der beiden Drosselklappen gibt fuer beide Zylinderbaenke.
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:46 Uhr.
