Alt 13.10.2013, 10:28   #1
Tinnemeneer
Fahrzeug: E64-645ci
Standard Blauer Qualm im Leerlauf
Hello,
First I want to apologise for writing in English. I live in the Netherlands and do speak a little german, but not enough to ask these questions (or understand technical answers).
Second, I want to apologise for intruding in your forum as I have a E64 instead of a E65/E66. The reason I come here is that you have had 3 years more to get into problems with the N62B44 engine then E60-E64 owners.
I already asked my questions on an American E60 forum but the answers were not conclusive, so I would like to have your opinion.
In case you wonder; I did ask permission to post this question from the moderators.
So these are my questions;
A week ago when I was in a traffic jam for half an hour my car started to blow a lot of blueish smoke out of 1 exhaust. My first thought was that one of the gaskets had blown but as I always have extra oil (for the engine) and water (for me) in the car I wasn't to worried, so I continued my journey home.
The next day at a BMW dealership they checked the CCV (I check it myself as well the next day, using Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) BMW CCV Replacement on N62 8 Cylinder Engine - YouTube as a guide), that the vacuum was to high and that the oild level was low.
The also told me I needed a complete engine revision, and that it would cost me approx E 6000,-.
As that is a lot of money to 'invest' in an almost 10 year old car I told them I'd think about what to do.
I already know it is no a uncommon problem with the N62 engine, especially after 150.000km, which my car has done as well (158.000km).
I also know that although -something- needs to be done, but I'm not sure what.
Do I need a complete revision, or is replacing the valve stem seals enough? To be honest, I don't know what valve stem seals are, or how much cheaper is is compared to a full revision.
Some people think a product named seafoam (Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Homepage - Sea Foam Sales Company) might help but I don't know if that is available in the Netherlands or Germany.
I also learned that it might have something to do with the valve lift being 0.8 instead of 0.3 when idling. I don't know if that makes sense as I'd expect that both banks of the engine would have the same height and the smoke only comes out of 1 exhaust.
I drive approx 1000km/week and the oil fill light hasn't started burning yet, so the oil useage is most likely lower then 1000:1.
Primary question;
Do you have any advise on what to do?
Secondary questions;
what would it cost to do this in Germany and do you know a good place to get it done near Papenburg or Leer?
If I do need a complete revision, would this be a good time to enlarge the engine to 4.8 or is that just a stupid idea? How much extra would that cost anyway? I know noellemotors used to offer engine enlargements for approx E 15.000,- but that included special crafted parts.
Kind regards,
Martin
Tinnemeneer ist offline   Antwort Mit Zitat antworten
Alt 13.10.2013, 11:08   #2
Hisholy
Geistiger Tiefflieger
Benutzerbild von Hisholy
Fahrzeug: 750D
Hello Martin,
the valve stem seals are down. It's typical for the N62 engine...
It's enough to change them, there's no need to do a complete engine revision.
Kind regards, Stefan
Hisholy ist offline   Antwort Mit Zitat antworten
Alt 13.10.2013, 12:04   #3
Tinnemeneer
Fahrzeug: E64-645ci
Zitat von Hisholy Beitrag anzeigen
Hello Martin,
Hello Stefan,
That's a good solid answer.
No hesitation, just the answer.
Any idea what that would cost, roughly?
Say in the order of E 500,-, E 1000,- or E 2000,- ?
Kind regards,
Martin
Alt 13.10.2013, 12:56   #4
Hisholy
Fahrzeug: 750D
The answer will not please you, in a regular garage between 4000 and 5000 €
Alt 13.10.2013, 13:17   #5
Tinnemeneer
Fahrzeug: E64-645ci
Hi Stefan,
I'm not pleased at all. :(
The difference in costs compared to a complete revision is a lot smaller than I expected.
Any idea how much cheaper a non-dealer would be? And do you happen to know one ?
I was happy for about half an hour after your first answer, now I'm depressed again.
Martin
Alt 13.10.2013, 14:09   #6
Hisholy
Fahrzeug: 750D
Geändert von Hisholy (14.10.2013 um 06:59 Uhr).
Stichworte
blaues qualm leerlauf
Motorraum: Blauer Qualm Andre 740i E65 BMW 7er, Modell E65/E66 21 17.08.2013 23:53
Blauer Qualm Giuly BMW 7er, Modell E38 8 19.08.2012 15:52
Blauer Qualm. arrif70 BMW 7er, Modell E65/E66 32 16.10.2011 11:10
Blauer Qualm.... Tim_Taylor BMW 7er, Modell E65/E66 8 12.10.2011 21:53
Blauer Qualm + Turbopfeifen Beckskompressor BMW 7er, Modell E38 2 14.05.2003 22:45
Alle Zeitangaben in WEZ +1. Es ist jetzt 08:27 Uhr.
