Alt 30.05.2005, 11:57   #1
pepaaa
Benutzerbild von pepaaa
Fahrzeug: BMW 740d (E38)
Standard TV - have you seen this before?
There's an interesting item sold on ebay - It looks like a pass-thru cable to enable TV. This looks interesting because it would be very easy to install, huh?
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://cgi.ebay.co.uk/ws/eBayISAPI.d...777087085&rd=1
Has anyone seen this before? Does it work?
Pepaaa
pepaaa ist offline   Antwort Mit Zitat antworten
Alt 30.05.2005, 13:05   #2
ahnungslos
Erfahrener Ahnungsloser
Benutzerbild von ahnungslos
Fahrzeug: G31 540i, Z4 M40i
Standard it works
hello prepaa,
yes it works... but if you have MK1 or MK2 you can have it cheaper: You can activate your Navi with onboard-switching. It also can be, that the onboard-activation works also for MK3. For MK4 it definitely does not work. Herefore you need this interface-cable. You will find the manuals for onboard switching at "Tips & Tricks".
ahnungslos ist offline   Antwort Mit Zitat antworten
Alt 30.05.2005, 13:16   #3
ferri
Hi @pepaaa
It works... I installed this item!
Greetz
Alt 30.05.2005, 14:23   #4
pepaaa
mine is MK3 and i don't think it can be unlocked. Or it probably can, but it is unknown ;-)
Guys, thanks for answering in English, I appreciate it :-)
Greetings!
Pepaaa
Alt 30.05.2005, 14:29   #5
ferri
Unlock Mk3? No problem...
buy it, install it (5min.) and look at TV....
Greetz
Alt 30.05.2005, 18:44   #6
StormRider
Lewer duad üs Slav!
Benutzerbild von StormRider
Fahrzeug: T4 VR6 - W210 E430
or install a mk2, unlock it, install the mk3 again and it stays unlocked. so did mine.
StormRider ist offline   Antwort Mit Zitat antworten
Alt 31.05.2005, 12:22   #7
pepaaa
hmm, installing mk2 - that sounds like a good plan. I'll have to find someone with mk2 in Ireland :-(
Alt 31.05.2005, 12:50   #8
Franz3250
Taxifahrer
Benutzerbild von Franz3250
Fahrzeug: S211
Ask your local BMW-Dealer.
It can be also a 3- or 5-series-car.
Franz
(Murphy)
Alt 31.05.2005, 15:11   #9
PETZ
Benutzerbild von PETZ
Fahrzeug: 740iL (E38) Bj. 06/2001
Ärger Bei mir work´ts halt nicht !!!
Hi Leutz,
habe ein genau gleich aussehendes Teil gekauft über
ibää bei "dark99dark". Ein Herr Darius Schnell von Caraudio
Systems in Ludwigshafen. Die Mitgliedschaft war einen
Tag nach meiner Ersteigerung beendet !!! Er hat mir das
Teil zugeschickt, aber es funktionierte leider nicht. Hab
mit Ihm gemailt und ich bekam ein zweites Teil zugesendet,
ohne Kosten und ohne das defekte zurück zu schicken !!!
Aber was soll ich sagen, das zweite funzte auch nicht
Nach erneutem email Kontakt wollte er mich anrufen, hab ihm
die Handynummer gemailt, aber leider nichts mehr gehört.
Wollte mich jetzt wegen der 75 euro auch nicht noch mehr
aufregen und hab nun 2 nicht funktioniernde Teile rumliegen !!
Wenn es eingebaut ist hat man auch beim fahren einen
leidlichen Empfang, aber sobald man in den Normalbetrieb
zurück möchte,also Navigation, Bordcomputer usw.geht das
nicht da das Bild dann durchläuft und nichts zu erkennen ist.
Habe MK4 mit 16:9.
PETZ
"Es ist mir scheissegal wer ihr Vater ist...solange ich hier angel geht hier keiner übers Wasser!"
BMW 7er-Forum - Musik die uns gefällt in Bild und Ton !!
Interner Link) http://www.7-forum.com/forum/group.html?groupid=16
PETZ ist offline   Antwort Mit Zitat antworten
Alt 31.05.2005, 16:04   #10
Franz3250
Taxifahrer
Fahrzeug: S211
leidlichen Empfang, ...
Mehr bringt die Freischaltung sowieso nicht. Ein qualitativ sehenswerter Empfang ist, wenn überhaupt, nur in der Nähe starker Sender möglich.
In meinen Augen ist die ganze Freischaltung nonsens, es sei denn, man hat einen DVD-Player im Auto.
Nur für TV während der Fahrt würde ich persönlich nicht einen einzigen Euro investieren.
Franz
Diagnose Adapter wian0011 BMW 7er, Modell E32 45 14.07.2007 01:09
Oel-Analyse Erich BMW 7er, allgemein 2 09.02.2004 19:51
Reparatur Anleitung Verlag Bucheli (so Schlecht!!!!) arc_master BMW 7er, Modell E32 17 29.11.2003 17:44
Kaufhilfe - Englisch-Deutsch Erich BMW 7er, Modell E32 10 20.11.2003 12:23
Can you change speakers when you have DSP? B12 5.7 Lang BMW 7er, Modell E38 3 28.04.2003 07:13
Alle Zeitangaben in WEZ +1. Es ist jetzt 13:20 Uhr.
