Alt 17.08.2007, 11:21   #11
Uncle Rocky
Danke Red Dragon...I'll ohm out the sensors to make sure it is giving the right signal (open circuit). I'll then see if the "warnung" goes out by itself.
Alt 17.08.2007, 13:25   #12
The Stig
Some say...
Benutzerbild von The Stig
Where do you come from, here in Germany and in the USA?
Your writing-style is an interesting mixture between german and english...
Quite good to understand, but it reminds me a little to "english for runaways"
Alt 17.08.2007, 13:25   #13
Uncle Rocky
I found the problem. Ich habe das problem gefunden.
The sensor must complete the circuit and/or give a ground (-) masse. when the bremslage (pads) are low. You just can't disconnet the sensor. The Check Control Module (CCM) will still think the pads need to be replaced.
Thanks everyone for your input. If you ever need any parts for your E32 we usually have lots in the American junkyard here in Mannhiem. A E32 V12 is cuurently being parted out.
Uncle Rocky (Roger)
Alt 17.08.2007, 13:39   #14
Uncle Rocky
I work in Mannheim and live in Ronneburg, Germany. Not really a E32 fan but like the engine for a 30-32 Ford coupe swap in October. Lot's of technical issues to resolve first and maybe it's not feasible. Imagine a carburated BMW V-12 in a RAT ROD Coupe. Too cool. I have a 55 Bel Air and a 49 Ford F1 hot rod with V-8 (5.7 liter and 7.4 liter). I'd like to do something different for my next project. Do you think it's possible?
Alt 20.08.2007, 23:23   #15
The Stig
Some say...
Possible is everything....
The issue is, that a BMW V12 has a lot more of modules and electronic components, than a V8 small- or big Block.
So you don`t need "only" mechanical knowledge, but also lots of electronic wisdom, especially about BMW systems.
But if you get it right, you will be an Expert
Xenon-Licht geht manchaml aus! MegaIceman BMW 7er, Modell E38 11 14.06.2012 09:15
Elektrik: Licht geht aus beim Beschleunigen Herby7 BMW 7er, Modell E38 10 01.11.2005 09:00
Elektrik: Licht geht nicht aus! alphornblaeser BMW 7er, Modell E38 6 21.10.2004 20:20
Licht spinnt / Motor geht aus / Tachobeleuchtung BOT BMW 7er, Modell E32 4 29.11.2002 00:02
mein Licht geht nich mehr aus *bg Reno BMW 7er, Modell E38 5 22.08.2002 18:28
Alle Zeitangaben in WEZ +1. Es ist jetzt 12:49 Uhr.
