Alt 05.12.2005, 14:49   #5
Sinclair
Benutzerbild von Sinclair
Fahrzeug: E38 750i 3/2001
Standard long-term charging the two batteries of 750i simultaneously
for this job I can only guess two possibilities, I have not done this already:
1) ask BMWs inside technicians, who can assure, that charging at the starting poles in the engine compartment will charge both batteries at the same time (I'm not sure if this works !).
2) if 1) cannot be answered definitely, do this by yourself-technique:
a) take the CTEK charger
b) connect minus to chassis Ground
c) split-off its plus-output by two resistors of 2.2Ohm/5W (cement type),
- connect one resistor "output" to the plus of the start pole in the engine
compartment, which charges the large starter batterie
- connect the second resistor "output" to the plus of the cigarette lighter
which charges the smaller bord batterie
d) limit the voltage output of the CTEK to about 13.2 V
e) if you apply this method, one should be shure, that both batteries may be held at e.g. 13.2 V for your long "winter sleeping time", without gasing effects.
Sinclair ist offline   Antwort Mit Zitat antworten
Fahrwerk: Bitte um mithilfe - Habe Einige Fragen zur Achslast beim 750i Teilemann BMW 7er, Modell E32 7 12.04.2005 16:52
Viele Fragen zum e38 750i Umbau/Tuning sk8terboy BMW 7er, Modell E38 14 18.03.2005 19:39
Motorraum: 740i mit gesperrten Diff aus 750i ! & jede Menge Fragen Teilemann BMW 7er, Modell E32 10 05.10.2004 11:47
Kaufberatung und Fragen 750i E32 HenningV12 BMW 7er, Modell E32 3 10.01.2004 15:37
Bin neu hier! Hallo! Und gleich Fragen zum 750i CD BMW 7er, Modell E38 8 06.11.2003 08:07
Alle Zeitangaben in WEZ +1. Es ist jetzt 04:12 Uhr.
