Alt 09.04.2011, 04:49   #1
Standard noch mehr Info
This diagram shows where the Jumper needs to be soldered. If you remove the module cover and plug it into the sockets, you can trace the BLK/RED/YEL and BLK/GRY wires and see that they lead to the relay contacts.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) BMWJUMPER.jpg picture by E32FAN - Photobucket
Alt 23.09.2016, 11:15   #2
Standard weitere Infos zum Thema lock sensor
Der Lock Sensor wurde mal wieder abgeschafft:
Group 64 Heating and Air Conditioning B 64 11 92 (3569)
Woodcliff Lake, NJ Product Engineering June 1992
SUBJECT: Air Conditioning Compressor Shutdown MODEL: E31, E32 75OiL
Situation: Air conditioning shuts down during heavy rain, or when driving through deep standing water. The customer complaint is loss of cooling. The condition disappears if the vehicle is stopped and restarted.
Cause:The air conditioning compressor clutch is disengaged by the slip monitoring function of the Air Conditioning Lock Sensor Control Module. This module continuously monitors engine speed and compares this to the air conditioning compressor speed. The magnetic clutch of the compressor is automatically disengaged by the lock sensor module if the amount of "slip" exceeds 30%. The intent of this system is to prevent broken V-belt or reduced engine cooling if the air conditioning compressor locks up.
If the vehicle is driven in heavy rain, or if standing water is splashed up into the engine compartment belt area, the V-belt and pulleys may get wet enough to cause slippage in excess of 30%. The lock sensor control module perceives this as possible air conditioning compressor lockup, and opens the clutch circuit to prevent damage. The control module will remain in this state, with the compressor clutch deactivated, until the ignition is turned off and back on, clearing the condition.
Note: In addition to slip monitoring, an engine coolant temperature check has been incorporated into the lock sensor control module on E32 vehicles produced since 9/89, and E31 vehicles since the start of production. If engine coolant temperature rises above 240 degrees F, the air conditioning compressor clutch is pulsed off at regular intervals to reduce engine load. If the coolant temperature rises above 250 degrees F, the clutch is switched off completely.
As of 9/92 production, the slip monitoring function of the Air Conditioning Lock Sensor Control Module will be dropped on both E31 and E32 models.
Solution:
If a customer complaint of A/C cooling loss is received, the following items should be checked before proceeding with this repair:
A/C compressor belt tension adjusted to specifications
No oil leaks have contaminated the A/C compressor belt, causing slip
A/C system pressure is within specification, not overloading compressor and belt.
If the above checks do not isolate the source of the slippage, proceed with the following repair. The remedy for this situation varies with the model and production date of the vehicle. Refer to the appropriate ETM for diagrams showing connector, pin, and control module locations.
#1 75OiL vehicles from start of production through 8/89:
Remove the Lock Sensor Control Module from the left hand side of the driver's footwell. The unit has two connectors (4 pin and 5 pin) and is located in the recess behind the kick panel.
Unplug the connectors X77 and X80 from the Lock Sensor Control Module body.
Remove Pin 1 of connector X77, and Pin 3 of connector X80 using a terminal removal tool.
Cut off the terminals and connect the loose wires with an insulated crimp connector. Shrink tubing may also be necessary to provide proper insulation.
Tape or tie-wrap the loose wires to the other harness wires.
Plug the connectors back into the control module, reinstall the control module, and reinstall the kick panel trim.
#2 75OiL vehicles produced from 9/89 through 8/91:
Replace the Lock Sensor Control Module with P/N 61 35 2 233 107. This replacement module does not contain the slip monitoring function.
Reconnect the electrical connectors and install the control module. Reinstall the kick panel trim.
#3 E31 vehicles from start of production through 8/92:
E32 75OiL vehicles produced from 9/91 through 8/92:
Remove the Lock Sensor Control Module from the left hand side of the driver's footwell. The unit has one connector (10 pin) and is located in the recess behind the kick panel.
Replace the Lock Sensor Control Module with P/N 61 35 8 360 039. This replacement module does not contain the slip monitoring function.
Reconnect the electrical connector and install the control module. Reinstall the kick panel trim.
Parts Information :
Lock Sensor Module 61 35 8 360 039
(10 Pin type: E31 from start through 8/92,
E32 from 9/91 through 8/92)
Lock Sensor Module 61 35 2 233 107
(9 Pin type: E32 from 9/89 through 8/91)
Alt 07.08.2017, 17:20   #3
heller-goisern
Benutzerbild von heller-goisern
Fahrzeug: Bmw 750 i By 88 E32,BMW e38 750il By 94 Audi 3.0 S-Line Quattro,Yamaha Fjr 1300 ,Honda 750 k2 By 71, Puch250 SGSSBy 56, Benelli 500 Quattro By 76,
Standard Elektrik Welche Funktion hat der Lock Sensor
Muss das Thema mal wieder hoch holen. Habe folgendes Problem :
Klimaanlage läuft soweit einwandfrei. Jedoch kann es passieren das nach einiger Zeit die Klima einfach nicht mehr funktioniert .Zeitlich definieren kann man das auch nicht .Das kann nach 5 min oder nach 2std. passieren. Habe nun fest gestellt das der Klimakompressor dann einfach nicht mehr mit läuft. Wenn ich dann das Fahrzeug aus mache und erneut starte läuft er wieder ganz normal. Jetzt weiss ich nicht genau was das Problem ist . Ich persönlich denke es müsste am looksensor liegen . Kann ja eigentlich nichts mit dem Klimakompressor zu tun haben . Vielleicht hat jemand das Problem schon mal gehabt und weiss mehr bevor ich alles zerlege.
heller-goisern ist offline   Antwort Mit Zitat antworten
Alt 07.08.2017, 18:42   #4
--750il--
Benutzerbild von --750il--
als er bei mir defekt war lief der kompressor halt gar nicht, ob es da ein zwischending gibt weiß ich nicht..
soweit ich weiß gibt es doch 2 lock sensoren, einmal klima(mit schwarzem stecker)
und einmal grün für alamranlage?!
Alt 07.08.2017, 21:30   #5
heller-goisern
Hallo 750il
Vornamen wenigstens wäre nicht schlecht.
Meine natürlich den Looksensor für die Klima .Den für die Alarmanlage kenn ich gar nicht.
Alt 08.08.2017, 10:01   #6
Der Lock Sensor fuer den Klimakompressor sitzt Fahrerseitig hinter dem Lautsprecher unten Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) BMW E32 Footwell Control Modules
Koenntest ja mal das Modul wechseln zum Testen.
Genug R134a ist drauf = nicht zu wenig und nicht zuviel?
Wenn der Druck zu niedrig oder zu hoch ist, dann schaltet der Kompressor auch ab.
Check auch mal den Stecker am Drucksensor, sitzt oben am Trockner.
Rechtes MAF Filter samt Kasten raus, dann kommste dran.
Klimakompressorrelais (siehe Bild oben im Link) koennte man aauch Testweise wechseln.
Alt 08.08.2017, 10:29   #7
MarieleM
Die 7er Pflegestation
Benutzerbild von MarieleM
Fahrzeug: E65-E38-E32-E23-E21
Standard Hallo Klaus,
der Locksensor überwacht die Drehzahldifferenz zwischen Kompressor und Wasserpumpe Kurbellwellenrad, ist dort eine hohe Abweichung so das der Riemen zerstört wird schaltet der Sensor den Kompressor ab.
Ich vermute auch eher den Druckschalter.
LG
Andreas
Andreas
www.bmw-pflegestation.de
Service und Handel
reducto Vertrieb
Stammtische: Interner Link) http://www.suedost.7-forum.com/
Kundenwagen: Interner Link) http://www.7-forum.com/forum/album.html?albumid=3366
Empfehlungen: Interner Link) http://www.7-forum.com/forum/9/empfe...tt-204936.html
Vom 7er Fieber meines Vaters angesteckt!
MarieleM ist offline   Antwort Mit Zitat antworten
Alt 02.08.2020, 15:33   #8
Zitat von Erich Beitrag anzeigen
This diagram shows where the Jumper needs to be soldered. If you remove the module cover and plug it into the sockets, you can trace the BLK/RED/YEL and BLK/GRY wires and see that they lead to the relay contacts. Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) BMWJUMPER.jpg picture by E32FAN - Photobucket
das alte Bild geht nicht mehr, hier noch einmal zum runterladen
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://s1011.photobucket.com/user/E...tml?sort=3&o=0
dann noch weitere Infos zu dem Thema von Johan:
750 lock sensor 3 pins compressor vs 1 pins compressor - my research
Author: Johan750 Posted on: 2013-01-17
As the pump in my 750 seems to leak uv dye around the compressor seal I got myself a new one. Later I saw the new one has only 1 connection in the electrical plug and thus missing the speed signal. And of course no where to mount it so I can't transplant is. So I did some schematics checking and came up with the following:
There are two types of lock sensors. The first one was used with the R12 upto 09/91. The second after that with R134a. As these have different plugs they don't "officially" interchange.
The part numbers of the old/R12 one in order they apeared:
61351382833
61351388718
61351390899
The part numbers of the new/R134a one in order they appeared:
61351392410
61358360039
The pin-out of the first type (two connectors):
x80-1 -- BL - to compressor rpm sensor
x80-2 -- BL/BR - to compressor rpm sensor
x80-3 -- SW/RT/GE - 12v from compressor relay
x77-1 -- SW/GR - To compressor clutch
x77-2 -- GN/BL/GE - 12v in Run/Start Fuse 29
x77-3 -- BR/SW - ground
x77-4 -- SW - to DME, EML,..etc. engine rpm
The pin-out of the second type (one connector):
x9988-2 -- BR/SW - Ground
x9988-3 -- SW/RT/GE - 12v from compressor relay
x9988-4 -- GN/BL/GE - 12v Run/Start Fuse 29
x9988-5 -- SW/GR - to compressor clutch
x9988-7 -- BR/GE - tap on cluster (x16-24) engine temp sensor
x9988-9 -- BR/VI - tap on cluster (x16-26) engine temp sensor
x9988-10 - SW - DME, EML, cluster,..etc. engine rpm
According to the ETK I need a new lock sensor 61358360039 and an adapter wiring set 64528391881. My guess is that the adapter wiring set goes between the car and the new lock sensor. But as the compressor cost enought and I recently had the chance to pick some parts off a 93 750i I am now the proud owner of a 61351392410 lock sensor with loose some wires.
So my plan is to splice the new plug into the wiring of the car, leave the temperature wires alone thus enabling me to use the newer lock sensor which doesnt need the compressor speed signal. If this doesn't work I'll tap into the cluster temp sensor and then it's 100% identical to the 92 upwards model years ans must work.
It seems to me in theory there are two other ways to bypass the old lock sensor:
1) Wire the input 12v from the compressor relay to the output to the compressor clutch thus bypassing the sensor
2) Also cut the x77-4 black wire so the lock sensor reads the compressor speed as 0 (as there is no speed sensor) and the rpm as zero (engine not running). This could fool the unit as it matches to two signals and disengages when the speed difference is 30% or more.
-->Both methods disable functioning of the sensor completely so use at own risk!
I found some postings on the net from Shogun and Hitmax which pointed me in the right direction. But as I collected all the part numbers and pinouts I though I'd share it just the same. -Johan-
Geändert von Erich (02.08.2020 um 15:45 Uhr).
Alt 26.06.2022, 15:37   #9
Standard altes Bild geht wieder nicht
und noch einmal der Lock Sensor, Bild von E32Fan Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://ibb.co/Z6y5GtD
Text:
I would open the A26 Lock Sensor Control Unit and solder a jumper wire across the Normally Open relay contacts. This will short X80 pin 3 to X77 pin 1 (shorting SW/RT/GE to SW/GR). If there are no pulses from the reed relay in the compressor (because the new compressor has no reed relay) then A26 will de-energize its relay, but we won't care because the contacts are now shorted. This will allow the compressor to run whenever K19 is energized and the pressure switches B7 and B8 are closed (just as in 735iL) . In later years, A26 was modified. The connector became X9968 which is not documented in the connector Views 8500. See 6450-22 at Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.e38.org/e32/e32_92_etm.pdf
I do not see any outputs from A26 that will bother EML, so I would not expect any problems from shorting the A26 relay. The SW/GR wire to EML is just the compressor run signal to inform EML that there is a compressor load.
Motorraum: Klimakompressor Lock-Sensor Kramer BMW 7er, Modell E32 18 02.01.2022 03:47
Motorraum: 728i Welche Funktion hat der Resonator,Luftführung... keke853 BMW 7er, Modell E38 2 20.02.2011 11:19
Elektrik: Klimakompressor Lock-Sensor 12Zylinder BMW 7er, Modell E32 2 21.02.2009 13:42
Welche Funktion hat der Integrallenker an der HA...? drmulthc BMW 7er, Modell E38 4 23.11.2006 18:45
Welche Funktion hat dieser Schalter ???????? bmwreini Autos allgemein 2 26.03.2004 16:53
Alle Zeitangaben in WEZ +1. Es ist jetzt 05:54 Uhr.
