Alt 08.08.2005, 19:39   #6
Standard langsam, langsam
Mach doch erst mal den test mit der Plastikeinkaufstuete.
Bei laufendem Motor die Verschlusskappe vom Oeleinfuellstutzen abnehmen.
This is an important check. Check the oil fill cap for vacuum, for instance by using a small thin plastic bag across the opening. Don't let it get sucked into the engine, as your weekend will probably ruined. If you don't have any crankcase vacuum but pressure instead, this could be related to faulty VCV valves. Patrick C about this: "You can do a quick test on the state of crankcase vacuum by removing the oil filler cap and stretch by two hands a plastic supermarket bag across the opening. The membrane should be seem pulled into the crankcase (but don't let go the bag!) if there is vacuum inside."
vorher E38 750, jetzt E38 750 oder 740 ? Bergfisch BMW 7er, Modell E38 68 08.01.2006 11:03
Frage an alle 750 Fahrer BMW-7er BMW 7er, Modell E38 9 06.03.2004 10:35
rücksitze vom 750 il in 750 i einbauen E32 BMWHarald BMW 7er, Modell E32 26 31.10.2002 11:31
DO-IL 750 Christian BMW 7er, Modell E32 13 02.09.2002 22:07
Alle Zeitangaben in WEZ +1. Es ist jetzt 03:28 Uhr.
