Modell F01/F02 |
Modelle |
07.06.2019, 12:19
7er-fan.
Fahrzeug: E32 750iL(90), E38 750iL(2000), F02 760Li(2015)
Nightvision nachrüsten, wo?
Where in Germany can I get the Nightvision retrofitted to my 760Li, 2014-10-01.
Sis können auch auf deutsch schreiben.
Thanks!
09.06.2019, 12:38
Fahrzeug: diverses
hi
nightvision isn´t retrofit possible.
the nightvision camera is save combined with a fsc-code depending on the VIN of your car.
in deeper law it belongs to "war-weapons" like tanks, machineguns a.s.o...
sounds funky and not in relation but it´s the law.
i did retrofit a nightvision years ago having best contacts to BMW itself,
it´s not unpossible, but unpossible without vitamin B
hacks and cracks might exist, like all does in dark law areas, but i would keep hands off that shit.
at least you need to have a camera within a VIN and electronic device that belongs to your car vin.
it´s not possible to order a vincode fsc in aftersales process for your VIN on official way, cause it´s generated in factory order.
nightvision is war-material index,...
sorry, it is like it is...
best regards
ray
Geändert von ray_muc (09.06.2019 um 12:44 Uhr).
09.06.2019, 15:01
7er-fan.
I understand and thank you for your answer.
I drove directly to you just after I bought my car in München.
Some people, like yourself, has done it - and I will do it.
https://www.bimmerfest.com/forums/sh.../topics/933281
10.06.2019, 10:08
Fahrzeug: diverses
Zitat von Mavve750
like i said, it is not impossible, but you need a hack for it.
main problem then is not to get it run, but after that your car wont be able to be programmed by any BMW Computer system again, thats what you should know about,...
and you need someone to write your "FA" - "custom-vehicle-letter" perfect to bring it up to work well with all other components in your car.
at least you should have the lates update version on the whole car before retrofitting, but keep also law in mind.
americans dont care, german law does
and !
i have had a lot of customers that had any of other retrofitting by using a "hack-simulator" and causing a lot of main problems killing the whole BUS-system.
these "hack-simulators" often get failure
best regards
Geändert von ray_muc (10.06.2019 um 10:45 Uhr).
Hybrid-Darstellung
