Sebastian, jezt ist die Verwirrung bei mir komplett, ich habe dieses Programm
geladen und er macht mir da Angaben,die ich nicht deuten kann. Z.Bsp dies
hier...
The configuration file must be named cpuz.ini and be present at the same directory level
as cpuz.exe. It contains the following :
[CPU-Z]
TextFontName=Verdana
TextFontSize=13
TextFontColor=000060
LabelFontName=Verdana
LabelFontSize=13
PCI=1
MaxPCIBus=256
DMI=1
Sensor=1
SMBus=1
Display=1
ShowDutyCycles=0
UseDisplayAPI=1
- TextFontName : Font used for the information boxes.
- TextFontSize : Size of the font used for the information boxes.
- TextFontColor : Color of the font used for the information boxes. Value is expressed in hexadecimal, and consists in a classic Red/Green/Blue color code : RRGGBB
- LabelFontName : Font used for the label boxes.
- LabelFontSize : Size of the font used for the label boxes.
- Sensor : Set to OFF (or 0) disables sensor chip detection and voltages measurement. 1 to enable.
- PCI : Set to OFF (or 0) disables the PCI information. This disables chipset, SPD and, depending on the hardware, sensoring information. 1 to enable.
- MaxPCIBus : Sets the maximum PCI bus to scan. Default value is 256.
- DMI : Set to OFF (or 0) disables the DMI (Desktop Management Interface) information. This concerns BIOS vendor and version, motherboard vendor and revision. 1 to enable.
- SMBus : Set to OFF (or 0) disables SMBus information : SPD, and, depending on the hardware, sensoring information. 1 to enable.
- Display : Set to OFF (or 0) disables the video card information reported in the validator. 1 to enable.
- ShowDutyCycles : Set to 1, switches the alternate clock computation method based on duty cycles. 0 to disable.
- UseDisplayAPI : Set to 1, uses the display driver to read the display adapters information.
Ob ich mal die Doppeläufige aus dem Tresor hole und den Rechner "wegpuste".........
![lol](images/smilies/lol.gif)
Viele Grüsse
Peter
