Alt 25.10.2003, 11:55   #1
Chanler
Standard Passenger door locking (English)
The passenger door will not lock using the remote or central locking sysytem. It will unlock fine, but will not lock unless you push down the knob with your hand. I replaced the lock actuator today, but still wont lock. The wiring is fine. The fuses are fine. The push down knob is not binding, it moves up and down easy. I don't want to pay a BMW dealer 200 Euro for something simple. But, I have tried everything. The lock actuator moves both ways, so the actuator is fine. I even tried adjusting it left and right, but no help. So, lock actuator is ok, wiring is ok, nothing binding. Can anyone help me with this problem?
Alt 25.10.2003, 12:33   #2
Crazy
Mitglied BMW7er-Club
Benutzerbild von Crazy
Did You enter Your car before by using the emergency unlocking procedure?
If yes, try to synchronize the central locking system by turning the key as shown here:
for the drivers door (left) or here:
for the other door.
You can try that anyway, before doing anything else.
Greets Crazy
[Bearbeitet am 25.10.2003 um 13:34 von CrazyDiamond730]
Crazy ist offline   Antwort Mit Zitat antworten
Alt 25.10.2003, 12:53   #3
Standard Norbert
das hat er schon probiert. Lenny hatte im E32 Register schon gefragt und da hatte ich ihm die Bilder gezeigt und auch die Seiten von Johan mit dem gebrochenen Halter und den Mikroschaltern.
Mit faellt aber auch nichts mehr ein.
Sorry Lenny, but maybe there comes another good idea from somebody.
Alt 25.10.2003, 13:04   #4
Standard Lenny
ddid you check all the fuses? Or even better change them.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) here something from roadfly
Alt 25.10.2003, 14:11   #5
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) check the wirings based on this
Here is another possibility how the GM reacts
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) click here
Alle Zeitangaben in WEZ +1. Es ist jetzt 08:38 Uhr.
