Alt 13.06.2005, 02:04   #1
Standard Kuehlschrank Armlehne hinten
Gearde auf Bimmerboard gefunden. Gibt es in England zu verkaufen. Brandneu.
Verkauefer hat 2 Stueck. Sollten aber doch auch irgendwo zu bekommen sein.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
Hier eingebaut in einen E34, "just fits right"
Fragen/Antworten dazu:
That's an actual cooling fridge, not just an insulated cold-box thing, right?? How much does it hold? A couple of bottles of Dom? Does it make much noise? I remember seeing it listed as an accessory and thought it would be great for long road trips. Oh yeah...how much?
Yep you can hear the fan when its on...but hey i can put up with it, ive found it tends to go away when you turn the dial on the radio up...(volume control)
for anyone in the uk, this is the fridge, if you remove the handle its just a fit where mine is, I fitted the temp sensor myself, but thats up to you not really nessasary.
then just wire up a switch so you can control it from the front seat
the second battery is also a good idea, ive fitted mine in the boot next to the jack, so i dont flatten the main battery
darren
Where does the heat from the peltier get exhausted to? Hopefully you're not keeping the trunk/boot warm?
no the heat goes into the car, but the output isnt noticeable, unless your trying to cool down a hot snack. If the food/drink is cool to begin with the heat exchanger doesnt need to work as hard
Innenraum: Armlehne hinten ausgehängt wie bekomm ich sie wieder rein ? 331BK BMW 7er, Modell E38 5 08.12.2004 19:37
Elektrik: Ausbau der Armlehne hinten C.K. BMW 7er, Modell E38 1 23.06.2004 16:14
Armlehne hinten Ausbau? NBA BMW 7er, Modell E38 3 02.07.2003 03:48
Wo liegen Lautsprecherkabel hinten? NCNMUC BMW 7er, Modell E38 8 25.06.2003 08:57
Alle Zeitangaben in WEZ +1. Es ist jetzt 00:12 Uhr.
