Alt 21.05.2006, 02:23   #1
BigKriss
Fahrzeug: 09/1988 BMW E34535iA M30B35
Standard e32 4 piston aftermarket brake linings
Hi gentleman, I am from Sydney, Australia and recently I recieved some 4 piston brakes from the e32 750i EURO (only available in Germany) frmo a ebay.de auction. Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.realoem.com/bmw/showparts...63&hg=34&fg=05
This is for a brake upgrade on my E34 535i. I know the calipers are a bolt on upgrade. What aftermarket pads are available?. All I can come up with are EBC linings (Green and Reds), I also know Textar make the OEM linings. Apart from these two options lining availability is very limited.
I also need 2 caliper rebuild kits - Part number 34111160188 - Number 10 in the diagram. Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.realoem.com/bmw/showparts...63&hg=34&fg=05
and the "set mounting parts" - Number 11 - Part number - 34111160189
Also, Erich (Shogun) from Japan, showed me this link - Interner Link) http://www.7-forum.com/forum/showthread.html?t=55398 - that states the heat resistant plates are not available any more. I'm not sure on what they are; are the heat resistant plates the metal rings on the end of the piston? My used calipers only came with three plates on each caliper. Should there be four?
I want to rebuild the calipers. Where/who is the best supplier in Germany to purchase these parts from. Sorry for the Enligh guys, I don't speak any German.
Regards
Kris
BigKriss ist offline   Antwort Mit Zitat antworten
Alt 21.05.2006, 12:23   #2
osl jaap
street-legal racer
Benutzerbild von osl jaap
Hello kriss,
The rebuild kit should be available at an Australian BMW dealership. The heat shield rings you refer to are the number 08 and 09 in the drawing and no longer available as part seperately. These rings protect the rubber seals against tear when pushing the pistons back to mount new linings.
For the linings can i provide you with two part numbers of linings i can buy in holland. the numbers refer to an 850 csi which uses the same 4/piston calipers but larger rotors. The TRW/Lucas linings are in my car with original BMW discs and work very well.
GDB 1161 TRW/Lucas-Girling
20309
0986424185 Bosch-ATE
BP 015
The mounting kit you mentioned is also only available throug the BMW dealer .
Ciao,
Osl Jaap
Alt 21.05.2006, 12:29   #3
DiaBoss
verarscht mich niemals!
Benutzerbild von DiaBoss
Fahrzeug: BMW 750i (E32) 6gang/Alpina
so ein Mist, kann kein English habe in der Schule nicht aufgepasst
Dia.
DiaBoss ist offline   Antwort Mit Zitat antworten
Alt 21.05.2006, 12:36   #4
Standard osl jaap
The BMW dealers in Australia seem to be a bit unflexible and their prices are even more than I have to pay in Japan. Lets talk about German list price times 3-4 = Australian dealer price.
If you or anyone can give Kris an email address, that would help kris very much.
Alt 21.05.2006, 12:41   #5
DiaBoss
@Erich..Angeber ..könnten Sie mir das auch mal BITTE Übersetzen.
Dia.
Alt 21.05.2006, 12:53   #6
Klar Dia, ich hab Kris ja an dieses Forum verwiesen, kenn ihn schon lange aus Bimmer.info
Uebersetzung:
die BMW Haendler in Australien scheinen ein weinig unflexibel zu sein und ihre Preise sind sogar noch hoeher als ich in Japan bezahlen muss. Wir sprechen von deutschem LP x 3-4 = Australischer Haendlerpreis nach Einfuhr.
Falls jemand Kris eine email Adresse geben kann, wo er einkaufen kann (in D oder Holland, Anmerkung von mir), das wuerde Kris sehr helfen.
Alt 21.05.2006, 12:58   #7
DiaBoss
...hast bei mir was gut
Dia.
Alt 21.05.2006, 13:06   #8
DiaBoss
... Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) www.hammer-gruppe.de
die haben mir immer gut geholfen...mit Fax/Auftragsbestätigung gehts bestimmt!!
Wenn das nicht klappen sollte, soll Er mir das sagen, ich könnte hingehen Ihm die Teile kaufen, wenn es nichts großes ist und schicke Ihm das denn zu!!
Ist ne Möglichkeit!!
Dia.
Geändert von DiaBoss (21.05.2006 um 13:13 Uhr).
Alt 21.05.2006, 13:39   #9
o.k., ich uebersetz das fuer kris mal. Kris ist vertrauenswuerdig, ich hab ihm auch schon geholfen und er mir auch.
Kris,
if you have problems to get the parts:
Dia,V12 says the company in above link might be able to help.
fax/oder confirmation should be o.k.
In case tou have probs, Dia.V12 would drive to that dealer there, buy the parts and send them to you, if the parts are not big.
In that case you can transfer the amount to his account in Germany including the shipping fee.
(In dem Fall koennte Kris dann das Geld an Dua.v12 ueberweisen inkl. der Versandkosten.
Alt 21.05.2006, 14:29   #10
DiaBoss
..ist OK
brauche aber dann auch sämtliche Daten, mit denen BMW auch was anfangen kann bzw.Irrtümer ausgeschlossen sind!!
Dia.
Es ist soweit! BMW Prospekte, EBAs, Unterlagen u.s.w. auf PDF! ferri BMW 7er, Modell E32 111 09.07.2013 19:51
Bremsenteile Gleich Bei E34 und E32 ?? Manek84 BMW 7er, Modell E32 3 13.08.2005 10:26
750i E38 vs. 750iL E32.... nach 6 Wochen Erfahrung. ferri BMW 7er, Modell E38 0 23.03.2005 08:13
Reparatur Anleitung Verlag Bucheli (so Schlecht!!!!) arc_master BMW 7er, Modell E32 17 29.11.2003 16:44
Alle Zeitangaben in WEZ +1. Es ist jetzt 08:52 Uhr.
