Alt 17.12.2006, 08:21   #1
Wikinger
Fahrzeug: E32-730iL V8 (10.93)
Standard Ausbau der Lichtmaschine
Hallo!!
Als neues Mitglied im Forum dachte ich gleich mal dieses zu nutzen und vielleicht ein paar Tips für den Ausbau der Lichtmaschine an meinem E32 (730 V8) zu bekommen...
Kann mir da einer helfen??
Wikinger ist offline   Antwort Mit Zitat antworten
Alt 17.12.2006, 08:45   #2
Ich habe da leider nur eine englische Info, sehr ungenau, aber beim M60V8 Motor scheint es nicht so einfach zu sein:
Had a noisy bearing on the alternator on my 740, and also showing only 13 volt output, so decided to get garage to put a new one on. (old one had good life doing 200k +)
Dont think any of realised what a job it was going to be !!
3 hours later, and after watching 2 mechanics pulling under the engine compartment, and one pushing from the top to remove the old one, then same configeration to fit the new one, mechanics finished with the comment that it was the first and last one of those they would fit !
To remove, not only the fan and belt tensioners had to be removed, but also the power steering pump (at least had fluid changed !!) and the oil filter assy.
Even then, there is no clearance to remove past the mounting plates.
Guess that the alternator is always fitted to engine before engine fitted !
One of the wires also had to be extended as you cant refit it to the original length.
Luckily the garage only charged £35 per hour for the 3 hours so final total charge just under £300. Guess would have been an arm and leg if a dealer had been asked to do it (eg if it had been a breakdown somewhere on the road) .
Alt 17.12.2006, 08:48   #3
Matthes
† 05.05.2017
Benutzerbild von Matthes
Fahrzeug: e34 540i Touring und andere Fahrzeuge
da hast du dir ja gleich ne undankbare Arbeit ausgesucht!
Also,vorn hoch,Pappe vorn unten ab,Lüfterkanal Lima weg,
Wasser runter,Kühler raus,Riemen weg,Lima lösen und drehen,
Kabel ab und raus damit!
Gruß,Matthes
Matthes ist offline   Antwort Mit Zitat antworten
Alt 17.12.2006, 10:33   #4
Wikinger
Wow!!!
Das ist ja super!! Mit einer so schnellen Antwort habe ich nicht gerechnet... Danke erst mal; die erste Antwort hat mir ja nicht gerade Mut gegeben, aber die Zweite um so mehr; hört sich ja nicht so schwierig an, nur den Kühler auszubauen, aber wo löse und spanne ich den Riemen und wie stark??
Alt 17.12.2006, 11:10   #5
Matthes
† 05.05.2017
... ich vergaß noch den Lüfterflügel,mit nem 30er oder 32er
Maulschlüssel abnehmen,Achtung: Linksgewinde!
Der Riemenspanner ist federbelastet,hat eine Klemmschraube
und einen Sechskant,um nach lösen der Klemmschraube den
Spanner gegen die Federkraft zurückzudrehen. Leuchte mal
von oben links hinter dem Kühler mit einer Lampe rein,dann
siehst du das Patent. Angeblich gibt`s Leute die wechseln die
Lima ohne Kühlerausbau,hab ich noch nicht geschafft!
Gruß,Matthes
Alt 17.12.2006, 11:17   #6
sebihees
740iA
Fahrzeug: E32-740iA V8 (EZ 13.07.1993), alpineweiss II, getönete Scheiben, schw. Leder, el. Sitze, Sitzheizung vorne und hinten, LPG Autogas, Alpina 17",
Matthes wo hast du immer diese Bilder her??? Hast du die TIS CD???
sebihees ist offline   Antwort Mit Zitat antworten
Alt 17.12.2006, 11:51   #7
Matthes
† 05.05.2017
...probier`s mal hiermit?
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.realoem.com/bmw/select.do
Alt 17.12.2006, 11:53   #8
jo, der Matthes hat es natuerlich auch schon mitbekommen, dass das neuderdings geht
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.realoem.com/bmw/diagrams/c/j/6.png
Alt 17.12.2006, 12:09   #9
Matthes
† 05.05.2017
Hallo Erich,
lange nichts gehört voneinander!
Ich hoffe dir gehts gut und einen schönen
dritten Advent nach Übersee.
Matthes
Alt 23.12.2006, 14:47   #10
Wikinger
Danke nochmals für die Hilfe... die Lichtmaschine ist getauscht und es hat ganz gut funktioniert, bis auf die Tatsache, dass es nicht gerade viel Platz zum herausnehmen der Lima gibt und man sie nur in einer speciellen Position herausbekommt, aber es funktioniert!!
Innenraum: Ausbau der Rueckenlehne der Ruecksitzbank Rudolf Fischer BMW 7er, Modell E32 3 17.06.2006 17:36
Karosserie: Ausbau der Plastikklipse der Tür-Zierleisten 730iA V8 BMW 7er, Modell E32 2 31.07.2004 13:39
Abhilfe - Steine in der Lichtmaschine Karl32 BMW 7er, Modell E32 5 23.02.2004 08:45
Lichtmaschine ausbau Rudi123 BMW 7er, Modell E32 3 14.02.2004 14:04
Lichtmaschine Ausbau bei 750 Karl32 BMW 7er, Modell E32 4 04.02.2004 07:41
Alle Zeitangaben in WEZ +1. Es ist jetzt 06:43 Uhr.
