Alt 19.10.2007, 16:10   #1
750 bmw
Standard burning smell in 735 i e32
I drove at the highway, when at some point , some "fehlermeldungen" appeard on the cockpit.
the faults were
ASC
Kofferraum hinten offen
Abblend licht
and die ABS light appears.
Al the faults came at the same time??
Also I smell a burned fragrance from somewhere in the car.
I stopped the car, turned it off, restart again and the fehlermeldungen were gone, but the burning smell is there and gets worse.
What can be the problem?
You can also reply in deutsch , i can understand deutsch , but i can't write it good.
750 bmw ist offline   Antwort Mit Zitat antworten
Alt 19.10.2007, 16:19   #2
peter becker
750i powered by ROTTALER2
Benutzerbild von peter becker
hallo
kannst du sagen,von wo dieser geruch gekommen ist ???
vom armaturenbrett???
oder evtl. von hinten, unter der rücksitzbank ist noch viel,viel an elektronik
eingebaut.
viele grüsse
peter
Alt 19.10.2007, 16:21   #3
That is difficult to analize. Is the smell coming from the engine room, or inside the car?
I would check the fuse boxes in engine room and under the rear seat.
Have seen some car where some old fuses did not work and then the fuse box melted down.
Or a cable was damaged and got ground contact.
735 ia e32 uwe1208 eBay, mobile und Co 5 24.07.2006 19:20
Innenraum: Bad smell pepaaa BMW 7er, Modell E38 2 29.07.2005 18:16
Alle Zeitangaben in WEZ +1. Es ist jetzt 02:16 Uhr.
