Alt 17.08.2008, 14:35   #1
sven-erik
Fahrzeug: E38-730i (07.94)
Standard Engine start problem.
Hello E38 fans.
If someone have an idee to a solution on my starting problem please reply.
A little more info, there a no ignition and no fuel availible when trying to start the engine, starter motor working ok.
Have also tested Relay K9 (Unloader relay ignition coils) relay OK
Best regards
Sven-Erik
Hello E38 fans.
My name is Sven-Erik, I live in Svendborg,Denmark and drive an e38 730I M60/1
engine. Model year 07/1994.
Its my hope somone can help me with following starting problem.
After driving few kilometer yesterday I parket the car, and now I am not able to start the engine. During the driving yesterday the engine stops momently a few times, but was able to start it again, but this morning the engine will
not start.
Engine turns over, but do not start. Found that fuel pump relay (K96) do not get power( relay tested and are working ok)
Fuse F57 and F17 OK
On fuel pump relay socket, messured +12 Volt on pin 6 and pin 8
Fuel pump tested with jumper over pin 6 and 2 on socket, pump working OK.
Even with jumper installed and fuel pump running, engine dont start.
It looks like the the Engine Control Module (DME) not activate the Fuel Pump
Relay K96. and some other(for me unknown ) start signal.
With a Peake R5/fcx tool have read a fault code 1A (Control unit supply)
and fault code 0d (Oxygen sensor,#19) and fault code 29 (Air mass sensor)
Have also done a reset and no fault code active after reset.
If DME module are defekt, is it just plug and play ore does replacement require
BMW Service.
Hope for some reply on this matter, please write in deutsch I read and understand deutsch, but do not write it very well.
Best Regards
Sven-Erik Ryborg
Geändert von sven-erik (18.08.2008 um 18:59 Uhr).
sven-erik ist offline   Antwort Mit Zitat antworten
Alt 18.08.2008, 19:15   #2
sven-erik
Hello again E38 fans.
Best regards
Sven-Erik
Hello E38 fans.
not start.
Fuse F57 and F17 OK
BMW Service.
Best Regards
Sven-Erik Ryborg
Alt 19.08.2008, 17:29   #3
mister cash
Fahrzeug: E38 740i
We have the same Problem
Interner Link) http://www.7-forum.com/forum/4/kerze...tot-85779.html
If you have it PLEASE Tell me !
mister cash ist offline   Antwort Mit Zitat antworten
Alt 20.08.2008, 00:13   #4
sven-erik
Hello Mister Cash and all other e38 fans.
After working two days on my starting problem I decided to get my car transported to BMW in Odense, arrived yesterday 1700, so hopefull I have some good news later to day.
I have try all my best to find the fault, but have to give up on this electronic
system. All related relays, fuses, and sensors tested, also done several reset and initialising of key, all without result, still no ignition and fuel.
Must be something with the Electronic Imobilation System.
I will let you now, best regards
Sven-Erik
Alt 20.08.2008, 15:32   #5
mister cash
Fahrzeug: E38 740i
We have checked the CRANKSHAFT SPEED SENSOR.
There is no resistance between PIN 1 and PIN 2.
I know from this Forum there must be 520 Ohm.
Check this to.
I hope you understand this.
Sorry my English
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.COM * BMW E38 740i SENSORS
Alt 20.08.2008, 23:34   #6
sven-erik
Hello Mister Cash.
Thanks for your reply, I am still waiting for the call from BMW Odense, cut very well bee this speed sensor, I didnt now that there shut bee that resistance between the pins, thanks for the info.
Will revert, best regards
Sven-Erik
Alt 26.08.2008, 19:48   #7
sven-erik
Hello e38 fans.
I got my car from BMW Odense this afternoon, the reason was a defekt Crankshaft Speed Sensor, therefore no start signal from the DMI.
Depending on Model Year some e38 are equiped with the EWS I ore the
EWS II. (EWS= Electronic Wegfarhspeere)
The EWS I are installed from beginning 1/94 up to 1/95, and operating thrue the Door Lock Cylinders and Switch, and give the oportunity to operate the starting motor even with a missing signal from the DMI, in this case a defekt
Crankshaft sensor did not trigger the DMI to enable the ignition and the fuel pump.
Reneved part: Crankshaft Speed Sensor Part No. 12141731887
Best regards
Sven-Erik
Alt 27.08.2008, 19:51   #8
mister cash
Fahrzeug: E38 740i
Hey i am happy that your E36 run. I still waiting to my sensor Ebay (you know someone are not speedfull in delivery). Have Fun
Alt 29.08.2008, 16:25   #9
mister cash
Fahrzeug: E38 740i
Standard E38
Oh E38
Our E 38 runs again Ja er läuft wieder
Start Engine Button wie beim Porsche.... LEXX BMW 7er, Modell E38 55 28.05.2014 12:00
Elektrik: "Engine Start"-Knopf E66-Fan BMW 7er, Modell E38 5 21.11.2006 18:20
Motorraum: Start Problem MisterL BMW 7er, Modell E32 15 25.07.2005 10:49
Elektrik: Engine Start Knopf Micu BMW 7er, Modell E38 66 08.05.2005 23:07
Sporadisches starkes Vibrieren der engine (Problem gelöst!) Tyler Durden BMW 7er, Modell E32 9 07.01.2003 22:21
Alle Zeitangaben in WEZ +1. Es ist jetzt 15:20 Uhr.
