Alt 09.08.2005, 19:16   #1
Harri
Daumen nach unten Klimabedienteil teilenummer und codieren
Hello,
Here´s a problem:
My friend has a 1994 740, the automatic A/C panel (with restwarm) and it has got pixelproblem (pixelfehler)with "old spec" panel with two LCD-panels.
So i read your very informative forum and found out, that facelift A/C panel should fit directly to the car.
I bought new facelift panel from the ebay (with restwarm), but when we fitted it, the A/C didn´t work correctly.
No problem i said, just code it at the BMW-dealer and it should work.
...well it didn´t. They couldn´t find the new panel with their diagnostics system at the BMW-dealer!!!
Could someone give information, what could be wrong. We have taken the battery cable off few times, but nothing helps.
Old panel partnumber:
64188369781
The new panel partnumber: (which doesn´t work correctly)
64118377581
BMW dealer recomended panel 64116901307, which should work.
Please give me some help, Sie können auch im deutsch anworten...
Harri
Finnland
Harri ist offline   Antwort Mit Zitat antworten
Alt 09.08.2005, 21:52   #2
boogie
Benutzerbild von boogie
Fahrzeug: CL600
I think you bought a broken unit, there is no code necassary if the unit was used only a new one has to be coded.
Good dealer`s always have one for a test!!
boogie ist offline   Antwort Mit Zitat antworten
Alt 09.08.2005, 22:30   #3
TomS
Hoher Priester
Benutzerbild von TomS
That´s not correct.
I must code my used unit at the BMW-dealer because it was a newer = pre-facelift unit.
Alt 10.08.2005, 10:31   #4
Harri
Ok, thanks for the answers. the local Bmw dealer said, that the 64118377581 is not suitable for replacing the old one, because their diagnostics can´t find the panel from the car´s system...
If someone has got some fact about the partnumbers and should that panel work if ain´t broken then, i´ll recieve them happily.
(BTW. I´ll have to that mention we tried the E39 panel also earlier, well i should have read you your forum before that. It didn´t work, as you already know. )
Alt 29.08.2005, 19:22   #5
Harri
..and now it works.
The local BMW-dealer didn´t know how to code it, changing dealer helped.
Auswechseln der LED's im Klimabedienteil Erich E32: Tipps & Tricks 13 01.03.2015 13:27
Dringend! Holzlenkrad Teilenummer leander BMW 7er, Modell E38 3 25.02.2005 10:28
Ein paar Fragen wegen Taco wechsel, codieren usw. mays_7er BMW 7er, Modell E38 5 23.12.2004 09:15
Klimabedienteil codieren ? Wozu ? Mongoman BMW 7er, Modell E38 19 31.05.2003 21:43
Alle Zeitangaben in WEZ +1. Es ist jetzt 09:34 Uhr.
