Alt 12.09.2004, 07:03   #1
Standard Einspritzduesen superbillig in USA
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Hier der Link zum Lieferanten von BOSCH ESD
Ausserdem werden immer die ESD fuer den Mustang fuer 7er angepriesen auf roadfly. Hier einige Kommentare:
Hello, I just installed a set of mustang injectors from fiveomotorsport. I am quite pleased with the results. Stumbling idle, and hesitation have been cured. Low end torque is slightly improved as well. Best $140 I have spent under the hood so far. PITA factor was a little higher than expected, but overall it was an easy job.
Stefan
1989 735i Euro 5-speed
Congrat's on the injector install. Did you get the Series 2 or the Series 3? I put in the FOTE - D5B Mustang 19 lb/hr Series 2 injectors a few years ago & had the same results you stated, & they're still working great. Did you use the stock Mustang o-rings that came with them or change them out to BMW o-rings? I used the Mustang o-rings that came with them & they slid in awefully loose but haven't had any leakage problems.
The only downside I've noticed is they tend to load up easily so I run 2 oz. of fuel injector cleaner per tank, skipping a dose now & then. Maybe once a year I put the full 6 oz. per 10 gal. dose in a 1/2 tank of gas & run that thru it just prior to an oil change & gets them idling smooth as silk again.
gale
92 735i 5-spd, 165k
Can I use the same Injectors or my 750
I'm Interested - Can I use the same Injectors or my 750 - Or do I have to research for another Mustang part number - Thanks !
The stock m70 injectors are the same as the what the e36 m50 uses, which is approx. 14 lb/hr. Check the 3rd & 4th columns. The Design 3 is an improvement over the Design 2 spray pattern but either will work.
Geändert von Erich (12.09.2004 um 14:19 Uhr).
Alt 12.09.2004, 10:41   #2
VollNormal
Normal ist, wie ich bin!
Benutzerbild von VollNormal
Die Amis sind da scheint's sowieso viel schmerzfreier, was die Ersatzteilbeschaffung angeht.
Aber warum haben die Probleme mit verstopften ESD? Liegt das am Sprit oder an den Düsen?
Und eins möchte mir bitte jemand erklären, der sich auskennt:
Da steht ja ein Durchfluss angegeben, z.B. 19lbs/h (das müssten ca. 8,62 kg/h entsprechend etwa 11,5-12 l/h sein), und das ist wohl der maximale Durchfluss. Wie hängt jetzt dieser max. Durchfluss mit der tatsächlich eingespritzten Kraftstoffmenge zusammen? Wenn das Maximum größer ist, muß ja vereinfacht gesprochen ein größeres Loch in der Düse sein. Geht dann in allen Betriebszuständen (außer Schubabschaltung) entsprechend mehr Sprit durch, als bei kleineren Düsen? Die Einspritzmenge wird doch über die Zeit geregelt.(?)
Ich brauche doch mal einen Grundkurs elektronische Motorsteuerung.
Tüssi, Andreas
Nomaal is dat nich ...
VollNormal ist offline   Antwort Mit Zitat antworten
Alt 12.09.2004, 11:53   #3
Herbie01
Benutzerbild von Herbie01
Fahrzeug: 730I V8 E32 Tartarini LPG
Stimmt einspritzmenge wird über die Zeit und über den Einspritzdruckgeregelt.
Wenn zuviel Sprit durch die Düse geht, das heißt diese zu lange auf ist, erkennt das die Lambda Sonde und die einspritzzeit wird verkürzt.
Die Durchflüßmenge bezieht sich auf eine Düse, 12l/h sollte pro Zylinder reichen. obwohl mein BC bei maximaler beschleunigung was von 299 liter pro Stunde angiebt. Nur leider kann ich keine Stunde voll beschleunigen -Schade eigendlich-
Ralph
Herbie01 ist offline   Antwort Mit Zitat antworten
Alt 12.09.2004, 14:26   #4
Standard Auszug aus T*S
Reinigung Einspritzventile im Ultraschallbad
dies gilt fuer alle Modelle mit D- und L-Jetronic und Dieseleinspritzanlagen.
Ursache: Mineralische Ablagerungen an den Einspritzventilen.
Laut BMW geschieht die beste Reinigung mit Ultraschallgeraeten, die den Handlern zum Kauf angeboten werden.
Arbeitsablauf: Einspritzventile ausbauen und gemaess der BA des Ultraschallgeraetes reinigen.
Dauer: 10 Minuten.
Sofort wieder einbauen und den Motor laufen lassen. Dadurch wird Korrosion der Einspritzventile durch die Bad-Fluessigkeit vermieden.
Ergibt sich nach Reinigung kein zufriedenstellendes Laufverhalten des Motors, so sind durch Abziehen der elektrischen Leitungen von den Einspritzventilen die nicht korrekt arbeitenden Ventile aufgrund unterschiedlicher Drehzahlveraenderungen zu ermitteln und zu ersetzen.
----------------Ende Zitat--------
Es ist also nicht unbedingt erforderlich, sofort alle Ventile auszutauschen, was sehr teuer ist. Man sollte den Haendler auf diese Moeglichkeit hinweisen, falls der Tausch aller Einspritzventile vorgeschlagen wird.
Und hier kpl. Prozedure des Testens mit Bildern, natuerlich auch aus USA
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Klack
Auf diesen Bildern vor Reinigung Durchfluss-Unterschied von max. 17%, danach 1-3%.
Alt 21.09.2004, 16:04   #5
VollNormal
Dies habe ich gerade gefunden, ist zwar Werbung, aber trotzdem interessant. Z.B ein Bild von einer aufgeschnittenen ESD.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.mft-berlin.de/pics/asnu_flyer_1.jpg
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.mft-berlin.de/pics/asnu_flyer_2.jpg
(Bilder sind recht groß, 270kB bzw. 340kB, deshalb nur als Link)
Alt 19.11.2004, 08:29   #6
Einführungsangebot!
Test & Reinigung, Vermessen Ihrer Bosch-Einspritzdüse
für nur 29,- Euro
je Stück inkl. MwSt. + neuen O-Ringen, Kappe und Filter (bei std. Boschdüsen) zzgl. Versand
Der Preis versteht sich für die von Ihnen angelieferten Düsen!
Das ist zu teuer. Wird in USA fuer $12/Stueck gemacht.
Neue gibt es dort ja schon um die $ 55,--
Alt 22.11.2004, 08:12   #7
RoadRunner
Benutzerbild von RoadRunner
Fahrzeug: E32-735iA (88), E30-320i Cab, E39-520i, E87-116i, F23-220i Cab
Ralph
Im Prinzip hast Du Recht. Allerdings funktioniert die Korrektur über die Lambdasonde nur im Teillastbereich und unter 4000 1/min.
Denn wenn entweder Vollgas oder >4000 1/min anliegen, wird nach einem fest programmierten Kennfeld eingespritzt - Stichwort Volllast-Anfettung. Die Lambdasonde wird dann ignoriert. So zumindest bei den R6. Bei V8 und V12 mag es etwas anders sein, das Prinzip ist jedoch gleich.
Wenn die Durchflußmengen der Einspritzventile nicht stimmen, läuft der Motor unter Volllast dann also entweder zu Mager oder zu Fett.
299 Liter/h sind für einen 3L V8 völlig unrealistisch. Ich würde einen Max-Verbrauch von ca. 70-80 L/h erwarten ...
Grüße, RR
RoadRunner ist offline   Antwort Mit Zitat antworten
E65 - floppt er nun auch in den USA ??? JPM BMW 7er, Modell E65/E66 14 05.02.2004 10:12
USA Highliner = L7 ? OlliE23 BMW 7er, Modell E23 33 23.12.2003 08:35
Sparen: ET-Preisunterschiede USA - D Erich BMW 7er, Modell E32 11 23.05.2003 10:34
745 iL (USA Modell) fish BMW 7er, Modell E23 3 27.04.2003 18:52
7er in den USA marek BMW 7er, Modell E32 11 24.08.2002 01:01
Alle Zeitangaben in WEZ +1. Es ist jetzt 11:14 Uhr.
