Alt 03.03.2005, 15:52   #1
Standard '90 750iL Elektrofrage- soll Samstag schrauben
Auf dem US Roadfly hatte einer sich gemeldet, der durch Zufall hier in Tokyo wohnt. Habe ihm angeboten, da mal ein bischen zu helfen mit Kollege Mike.
Endlich kann ich auch mal einem am Auto direkt helfen
Hier mal die Kopie seiner Meldung:
This afternoon for the first time, I started my car and the engine had this vibration and it sounded low pitched. I thought maybe I was in limp mode so I popped the hood to check. Both sides were running. So I shut the car off.
Now a little history:
Just prior to starting I checked the fluids and added about a liter of water to the resovoir tank. (Note: I had recieved a check coolant level in the past couple months and have been topping up) I can not see any coolant leaks and I am afraid it could be a head gasket? The oil level hasn't changed nor is there any usual signs of coolant and oil mixing (ie white sludge under oil cap, frothy oil on dipstick)I couldn't smell any coolant burning nor was there any on the ground. I started it up again and noticed a little bit of white exhaust (I live in Tokyo and the temp is above 0 celcius but still a little cool) After warm up the white exhaust disappeared. I think this is normal. The engine still has the vibration, and after driving around the block and letting the engine warm up the temp gauge reads normal (12 o'clock), with no overheating problems prior.
In the past month I changed the catalytic converter on the left side, from the exhaust manifold to the muffler with a non OEM part (BMW after market part bought from ArizonaAZ)The catalyizer did not have a spot on the pipe to insert the exhaust temp sensor. I doubt however, this could be the problem as there have been no instances of this vibration until today. The funny thing is that I drove the car this morning and aside from it being cold from the night before it ran normally.
Does anyone have any ideas on what I should be looking for? I know I have to find the coolant leak, but is that the probable source of the problem?
Dann hat er mir jetzt noch per email folgendes geschickt:
When the garage installed the cat they showed me on the lift and the O2
sensor is installed but further down the pipe close to the muffler is a wire
with a sensor on it the garage called it an
Kuehlwasserverlust ist klar, keine Frage. Muessen wir suchen.
Aber was ist mit diesem exhaust Temperature Sensor der hinten kurz vor dem Endschalldaempfer sitzen soll?
Hat dieser Temp-fuehler dort irgend etwas mit dem Motormanagement zu tun?
Wenn dieser nun nicht drin ist an dem Auspuff, den er aus USA importiert hat, wie kann sich das auswirken auf das Motormanagement und was kann man evtl. machen.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) geht hier um die Nummer 28, Temperatursensor.
Alt 03.03.2005, 16:04   #2
freak
the real freak since 2002
Benutzerbild von freak
Jupp, hat was mit dem Motormanagment zu tun ...
Der Thermofühler ist mit sicherheit auch bei einem US-Modell vorhanden ...
Gruß ...
@freak
Alt 03.03.2005, 16:20   #3
Standard Danke Freak
anscheinend ist ja nun dieser Auspuff fuer die eine Seite aus USA, die jetzt nachtraeglich installiert wurde, ohne dieses Gewinde. (ist nicht orginal BMW, das ist sicher)
Muss mir das erst mal anschaun, ob der Fuehler jetzt da so locker rumhaengt oder was sie gemacht haben.
Nun koennte man ja notfalls so ein Gewinde aufschweissen, Loch natuerlich vorher bohren, ist klar.
Weis jemand zufaellig, was das fuer ein Gewinde ist fuer den Fuehler?
Teilnr. ist 11781722763, Pos. 28
Kann's hier aus dem online Ding nicht finden.
Oder geht es irgendwie, das Ding lahmzulegen?
Bin ja nun nicht der Elektr.-Fuzzy, mehr auf der mechanischen Seite.
Also alle Vorschlaege sind wilkommen.
Alt 03.03.2005, 17:20   #4
freak
Standard Re.
Hmmm, das das Gewinde für den Fühler fehlt, habe ich nicht aus dem Englischentext rausgelesen bzw. nicht konzentriert genug gelesen, da mein Englisch nicht mehr so gut ist
Der Fühler ist nicht Lebenswichtig, wenn Ihr in Japan keine strengen Abgasuntersuchungen/Grenzwerte wie in einigen US Staaten habt ...
Ich denke mal, dass das Teil ein Importteil ist und nicht in USA Freigegeben ...
Ich kann dir leider nicht sagen, welches Gewinde der Fühler hat, aber es ist sicherlich kein Problem, das Gewinde vom Fühler mit einer Lehre auszumessen und ein Gewinde am Kat. zu Bohren - somit wäre der Thermofühler wieder am original Platz und liefert Daten für die DME ...
Gruß ...
@freak
Alt 03.03.2005, 18:04   #5
Da bist Du wohl auf der richtigen Spur. Koennte sein, dass das Auto original eine Spezifikation fuer Kalifornien hat, wo das mit Abgaskontrolle besonders streng ist.
Den einen Kat (nicht Original BMW) hat er aber aus Arizona importiert. Da ist das vielleicht nicht so streng.
Geht nur darum, dass der Motor wieder rund laeuft.
Wenn dieser eine Sensor nun immer 'Kat kalt' meldet, steuert die eine Motronic ja immer dagegen.
Haben denn deutsche M70 Motoren einen separaten Temp Fuehler hinten auf dem Kat und vorne dann die Sonden? Oder nicht, evtl. eingebaut in den Lambdasonden?
Dann koennte man ja theoretisch einfach beide Temp-fuehler einfach an ECU's abklemmen, oder?
Oder eben ein Gewinde draufschweissen lassen am Kat-Ende. Selber haben wir die Moeglichkeit nicht dazu hier.
Abklemmen waere einfacher. Falls es geht/funktioniert. Welche Pins waeren das? Koennte man ja versuchweise mal machen.
Alt 03.03.2005, 19:51   #6
virtual
inaktiv, keine gültige e-Mail
Fahrzeug: 750iL
Also ich hab den Fühler nicht und er läuft trotzdem gut.
Ersetzen kannst du das Teil wahrscheinlich mit einem Widerstand, dazu müsste man den Fühler bei Betriebstemperatur messen und diesen Wert als festes Teileinbauen.
Ich denke mit Loch bohren und gewinde drauf ist die beste Lösung.
Es heisst, der klügere gibt nach...........das bedeutet, den Dummen die Welt überlassen.
virtual ist offline   Antwort Mit Zitat antworten
Motorraum: M70 Umfrage: Ölleitung der Nockenwelle/lockere Schrauben Erich BMW 7er, Modell E32 17 31.03.2019 16:32
e32 750iL? Oder e38 750iL? Oder e39 M5? ferri BMW 7er, Modell E32 7 11.11.2003 08:09
Noch ein paar Fragen wegen 750il! KJ750IL BMW 7er, Modell E38 10 19.10.2003 12:20
Meeting nächsten Samstag in Weilheim Tranceshark Aktivitäten, Treffen, ... 10 22.08.2003 21:57
Alle Zeitangaben in WEZ +1. Es ist jetzt 09:03 Uhr.
