BMW 7er, Modell E23
Alt 30.11.2005, 06:21   #1
Petri
Fahrzeug: 735i highline
Standard Sport steering wheel
Hello, does anyone knows if sport steering wheel from any other bmw models woud fit to E23.
Best regards
Petri
Petri ist offline   Antwort Mit Zitat antworten
Alt 30.11.2005, 08:17   #2
45er
Benutzerbild von 45er
Fahrzeug: 97er 740i 4.4-Handschalter
Hi Petri,
If your E23 was built earlier than 9/1985 you got coarse splines, you can fit wheels from E12, E21 (1979->secound series), and early E24 series (first series ->1982).
If it's built after 9/1985, you got the fine splines and unfortunatly, there's nothing that I'm aware of would fit ... "maybe" those from E24 secound generation???
Regards,
45er
45er ist offline   Antwort Mit Zitat antworten
Alt 30.11.2005, 09:25   #3
Petri
Hello 45er, seems that I have a bad luck in this case because my 735iA
was manufactured 3/86. But if I remember correctly, there was this same
transition to fine splines in E28 series also. Do you think it would be
possible to use E28 series steering wheel which is made after 9/85.
Best regards
petri
Alt 30.11.2005, 10:54   #4
45er
Standard E28 had Allways fine splines...
I'm not sure about E28... but I think it dosen't fit. What I know, is that E30 dosen't fit because of it's steering/key lock system and I've heard that E28 & E30's fit each other.... So, "logically" I don't think E28 fit E23's of 9/1985 and later... but again, this is only my WAG...
All that been said, I didn't have that knowledge like 6 years ago when I fit a coarse wheel on my 1986 (735i) ... I never did, noticed any thing "wrong" with it & drove it around like 2 years with that wheel on. Then I bought my 1982 (745i) and decided to fit that wheel on it ... then I noticed that wheel surprisingly "fell down" along steering columne splines just by itself... so easy it has to fit when splines're right On my 1986 I had to push it down a bit... oh nothing savage (otherwise I'd stoped!!), just it needed to be pushed in, gently...
Regards,
45er
Geändert von 45er (30.11.2005 um 11:03 Uhr).
Alt 30.11.2005, 13:35   #5
Kalsi
eingefahrenes Mitglied
Fahrzeug: BMW 735i E65 11.2003
The early E28s had also coarse splines, but I think the locking system is different from the E23. E28, E30 and E32 (and I think also E34) fit each other. I know that absolutely for sure, because I'm using the same steering wheel (original BMW 3-spoke sports) for a long time now and had it in my E28, in my E30 and now I drive my E32 with it ;o)
Wer langsam fährt wird länger gesehen ;o)
Kalsi ist offline   Antwort Mit Zitat antworten
Alt 30.11.2005, 13:56   #6
45er
OK, this explains what I was thinking... E30 & E28 are the same, then not the same as E23... even with fine splines... only because steering wheel lock system
Regards,
45er
Felgen/Reifen: Fragen zu Breyton Magic Sport 22" D.Schiffers BMW 7er, Modell E65/E66 19 10.11.2005 21:39
1x Michelin Sport 235/50/18-ca.5mm Skorpo Suche... 2 30.08.2004 16:25
Reparatur Anleitung Verlag Bucheli (so Schlecht!!!!) arc_master BMW 7er, Modell E32 17 29.11.2003 17:44
Alle Zeitangaben in WEZ +1. Es ist jetzt 10:40 Uhr.
