25.04.2003, 23:33
Lampenträger & Standlichtringe
ich möchte die Standlichtringe einbauen und die Lampenträger Chrom Lakieren.
Meine Frage geht beides auch bei Xenonlicht. Hat jemand das verbaut der auch xenon hat.
Danke
26.04.2003, 20:40
Fahrzeug: B12 (E38)
Jepp, geht.
Daniel
27.04.2003, 12:34
Diebstahlopfer
Fahrzeug: E38-750iLA
Ich hab' zwar "nur" die Lackierung gemacht, Du kann Dir aber trotzdem mal ein paar -> Bilder anschauen.
Gruß, Möhre
27.04.2003, 16:09
Fahrzeug: X3 2.0i E83, X1 2.0D E85, VW Golf Cabrio 155
Hier findest Du die Einbauanleitungen für die Standlichtringe.
Gruß Helge
http://www.7er.com/modelle/e38/standlichtringe.php
28.04.2003, 01:43
Fahrzeug: E38-1998 (740iL)
parking light rings from an American
[ quote][i]Original gepostet from 740erblack[/i ] hello, I would like to insert the parking light rings and the bulb holders chrome Lakieren. My question goes both also with xenon light. Someone has blocks also xenon has. Thanks [/ratio ]
Hello together,
I created my own modification to add rings to "Bettie" my 98 740iLA (09/97) using the Schott rings and fiber cables. The steps to dismantle and install the rings are similar to those posted on 7er.com but I used the OE parts from Schott to provide the light via fiber optical cables. To install them I modified the headlight inner workings somwhat and cut clearance openings in the top of the housings. I have since read that another E38er did not use the Schott fiber clips and could fit them in without cutting the openings like I did. At the same time that I created this modification, I also developed a way to upgrade the headlights to the facelift style using only parts and @ $300.00, versus buying new headlights.
The steps I used to build my own parking light rings source light housings and attachments for the fibers are shown in detail with photos on my CarDomain web pages also I show how to update the headlights to facelift style. Link to this information via my signature below.
Alta Vista translation:
Hallo zusammen, verursachte ich meine eigene Änderung, um Ringe "Bettie" hinzuzufügen meine 98 740iLA (09/97) die Schott Ringe und die Faserkabel verwendend. Die Schritte, zum der Ringe abzubauen und anzubringen sind denen bekanntgegeben auf 7er.com ähnlich, aber ich benutzte die OE Teile von Schott, um das Licht über optische Kabel der Faser zur Verfügung zu stellen. Um sie anzubringen änderte ich die somwhat und Schnittabstand Öffnungen Funktionen des Scheinwerfers inneren in der Oberseite der Gehäuse. Ich habe, da gelesen, daß ein anderes E38er nicht die Schott Faserclips benutzte und sie innen passen könnte, ohne die Öffnungen zu schneiden, wie ich. Zur gleichen Zeit als ich diese Änderung verursachte, entwickelte ich auch eine Weise, die Scheinwerfer zur Verschönerungart mit nur Teilen zu verbessern und @ $300,00, gegen das Kaufen der neuen Scheinwerfer. Die Schritte, die ich pflegte, meine eigenen Parkenlichtringquelllichtgehäuse zu errichten und Zubehöre für die Fasern werden im Detail mit Fotos auf meinen CarDomain Netzseiten gezeigt, auch ich zeige, wie man die Scheinwerfer zur Verschönerungart aktualisiert. Verbinden Sie mit diesen Informationen über meine Unterschrift unten.
Gruss, John
28.04.2003, 09:56
Fahrzeug: B12 (E38)
a well done job !
But using fibre is not possible with the "old" headlights :-(
(There is no place)
Sehr gut gemacht!
Leider sind die Ringe mit Glasanschluss für die "alten" Scheinwerfer zu gross :-(
(Da ist wirklich absolut kein Platz)
Daniel
[Bearbeitet am 28.4.2003 von B12]
