| BMW 7er, Modell E38 |  |  |
| Varianten |
| Detail-Infos |
| Interaktiv |
 |    - Anzeige -
		|  21.07.2011, 23:15 | #1 |
	| Erfahrenes Mitglied
Fahrzeug: E38-730i (05.95), 10.2007: 56.700km, 12.2008: 82.600km, 10.2009: 106.500km, 12.2009: 112.500km, 10.2010: 130.000km, 04.2011: 147.000km, 2020: 240Tkm
				 Bei TEST 14: DIAG: 1 D7 81 035
 weiß jemand, was die obige Zahlenkombination im Geheimmenü bei Test #14 bedeutet?
 Vielen Dank
		|  21.07.2011, 23:51 | #2 |
	| Gruß, Christoph
Fahrzeug: -
				 Aus dem e39 Forum
 Ob es so stimmt sei in den Raum gestellt
		| 01 - Fuel pump relay 02 - Idle speed actuator (close)
 03 - “Fuel Injector, Cyl #1”
 04 - “Fuel Injector, Cyl #3”
 05 - “Fuel Injector, Cyl #2”
 06 - Timeout SMG-CAN
 07 - “Intake camshaft position sensor, Cyl #1-4”
 08 - “Intake camshaft position sensor, Cyl #5-8”
 09 - “Knock sensor, Cyl #1-2”
 0A - “Exhaust camshaft position sensor, Cyl #1-4”
 0B - “Exhaust camshaft position sensor, Cyl #5-8”
 0C - “PreCat oxygen sensor, Cyl #5-8”
 0D - “PreCat oxygen sensor, Cyl #1-4”
 0E - Tank small leak
 0F - “Crankshaft/Camshaft position correlation, Cyl #1-4”
 10 - Crankshaft sensor
 12 - Map controlled thermostat actuator
 13 - Secondary air pump relay
 14 - Starter relay
 15 - “Exhaust camshaft VANOS retard valve, Cyl #1-4”
 16 - “Exhaust camshaft VANOS advance valve, Cyl #1-4”
 17 - “Ignition Coil, Cyl #2”
 18 - “Ignition Coil, Cyl #3”
 19 - “Ignition Coil, Cyl #1”
 1A - “Ignition Coil, Cyl #8”
 1B - DM-TL switching valve
 1C - Map controlled thermostat control
 1D - Idle speed actuator (open)
 1E - “Control unit self-test, A/D converter monitoring”
 1F - “Fuel Injector, Cyl #5”
 20 - “Fuel Injector, Cyl #6”
 21 - “Fuel Injector, Cyl #4”
 22 - “Fuel Injector, Cyl #7”
 23 - “Fuel Injector, Cyl #8”
 24 - Evaporative emission purge control valve
 25 - “PreCat oxygen sensor heater control, Cyl #1-4”
 26 - “PreCat oxygen sensor heater control, Cyl #5-8”
 27 - “AfterCat oxygen sensor heater control, Cyl #1-4”
 28 - “AfterCat oxygen sensor heater control, Cyl #5-8”
 29 - “Air mass sensor, Cyl #1-4”
 2A - “Vehicle speed input signal, hardwired ‘A’ signal”
 2B - Radiator outlet temperature sensor
 2C - Thermal oil level sensor
 2D - Drive-by-wire throttle actuator driver
 2E - Fuel consumption (KVA) signal output
 2F - Engine RPM (TD) signal output
 30 - A/C Compressor relay
 32 - “Ignition Coil, Cyl #4”
 33 - “Ignition Coil, Cyl #6”
 34 - “Ignition Coil, Cyl #5”
 35 - Electronic fan (relay)
 36 - Battery voltage behind main relay
 37 - “Ignition Coil, Cyl #7”
 39 - “Air mass sensor, Cyl #5-8”
 3A - Sensor voltage supply 1
 3B - Sensor voltage supply 2
 3C - “Pedal position sensor 1, master measurement”
 3D - “Pedal position sensor 2, master measurement”
 3F - Secondary air switching valve
 41 - “Throttle position sensor 2, slave measurement”
 42 - EWS interface
 43 - “Intake camshaft VANOS advance valve, Cyl #1-4”
 45 - “Knock sensor, Cyl #5-6”
 46 - “Knock sensor, Cyl #3-4”
 47 - “Knock sensor, Cyl #7-8”
 48 - “Intake camshaft VANOS retard valve, Cyl #1-4”
 49 - “Air mass sensor, plausibility”
 4A - “Intake camshaft VANOS advance valve, Cyl #5-8”
 4B - “Intake camshaft VANOS retard valve, Cyl #5-8”
 4C - Ambient pressure sensor
 4D - Intake air temperature sensor
 4E - Coolant temperature sensor
 4F - Exhaust gas temperature sensor
 50 - Switch-chain grip
 51 - MFL interface signal
 52 - Muffler flap
 53 - “Exhaust camshaft VANOS advance valve, Cyl #5-8”
 54 - “Exhaust camshaft VANOS retard valve, Cyl #5-8”
 55 - “Throttle position sensor, master measurement”
 56 - CAN buss offline
 57 - “AfterCat oxygen sensor voltage, Cyl #1-4”
 58 - “AfterCat oxygen sensor voltage, Cyl #5-8”
 59 - “Control unit self-test, Safety Concept slave check”
 5A - “PreCat oxygen sensor aging, Cyl #1-4”
 5B - “PreCat oxygen sensor aging, Cyl #5-8”
 5C - “AfterCat oxygen sensor aging, Cyl #1-4”
 5D - “AfterCat oxygen sensor aging, Cyl #5-8”
 63 - “Control unit self-test, Safety Concept master check”
 64 - Tire pressure left front
 65 - Tire pressure right front
 66 - Tire pressure right back
 67 - Tire pressure left back
 69 - “Engine coolant temperature, Plausibility”
 6A - Brake light switch
 6B - “Control unit self-test, pre-drive check of drive-by-wire system”
 6C - Switching valve oil circuit left
 6D - Switching valve oil circuit right
 6E - Sport switch LED indicator
 6F - “Pedal position sensor 1, cross check”
 70 - “Pedal position sensor 2, cross check”
 71 - “Intake camshaft VANOS position control, Cyl #5-8”
 72 - “Exhaust camshaft VANOS position control, Cyl #5-8”
 73 - “Control unit self-test, internal ECU temperature”
 74 - Servotronic valve current
 75 - Servotronic speed signal
 76 - Throttle position sensor 1
 77 - Throttle position sensor 2
 78 - “Throttle position sensors, cross check”
 79 - “Throttle position sensors, both bad”
 7A - “Control unit self-test, master processor”
 7B - “Bus offline, SMG-CAN”
 7C - Active engine bearing
 7D -Spoiler adjustment
 7E - Fuel pump crash shut-off
 7F - DM-TL module
 80 - Idle speed deviation
 82 - “EWS signal, manipulation detected”
 83 - “DSC intervention, plausibility”
 84 - DSC message timeout
 85 - Steering angle sensor message timeout
 86 - Instrument Cluster message timeout
 87 - Vehicle speed signals (both Discrete & CAN)
 88 - Idle speed controller
 89 - Jet stream pump
 8A - Differential lock
 8B - Cruise control system
 8C - Engine noise too high
 8D - “Fuel level, plausibility”
 8F - E-box fan
 90 - “Fuel control, Cyl #1-4”
 91 - “Fuel control, Cyl #5-8”
 95 - Misfire w/ empty fuel tank
 96 - “Control unit self-test, memory test master”
 97 - “Control unit self-test, driver diagnostics chain”
 98 - “Control unit self-test, communication master”
 9B - “Control unit self-test, adaption EEPROM master”
 9C - “Control unit self-test, adaption EEPROM slave”
 9D - “Control unit self-test, memory test slave”
 9E - “Control unit self-test, communication slave”
 9F - “Control unit self-test, knock detection IC 1”
 A0 - “Control unit self-test, knock detection IC 2”
 A1 - Knock control
 A2 - “Crankshaft/Camshaft position correlation, Cyl #5-8”
 A3 - “Control unit self-test, master resets”
 AA - “Secondary air system, flow too low”
 AB - “Secondary air system, valve sticking”
 AC - VANOS pressure storage valve
 AD - Starter switch input
 AE - “Air-fuel adaptation, Cyl #1-4”
 AF - “Air-fuel adaptation, Cyl #5-8”
 B0 - “Air-fuel adaptation at idle, Cyl #1-4”
 B1 - “Air-fuel adaptation at idle, Cyl #5-8”
 B2 - “Catalyst system efficiency, Cyl #1-4”
 B3 - “Catalyst system efficiency, Cyl #5-8”
 B4 - Tank leak detected
 B5 - Filler cap open
 B6 - “Injection driver 1, over temp.”
 B7 - “Injection driver 2, over temp.”
 B8 - “Intake camshaft VANOS position control, Cyl #1-4”
 B9 - “Exhaust camshaft VANOS position control, Cyl #1-4”
 BA - “Ignition output stage, Cyl #1”
 BB - “Ignition output stage, Cyl #2”
 BC - “Ignition output stage, Cyl #3”
 BD - “Ignition output stage, Cyl #4”
 BE - “Ignition output stage, Cyl #5”
 BF - “Ignition output stage, Cyl #6”
 C0 - “Ignition output stage, Cyl #7”
 C1 - “Ignition output stage, Cyl #8”
 C2 - “Control unit self-test, cruise control shut-off”
 C3 - “Control unit self-test, torque manager monitoring”
 C4 - “Misfire, Cyl #1”
 C5 - “Misfire, Cyl #2”
 C6 - “Misfire, Cyl #3”
 C7 - “Misfire, Cyl #4”
 C8 - “Misfire, Cyl #5”
 C9 - “Misfire, Cyl #6”
 CA - “Misfire, Cyl #7”
 CB - “Misfire, Cyl #8”
 CC - “Misfire, multiple cylinders”
 CD - “Misfire during warm-up, Cyl #1”
 CE - “Misfire during warm-up, Cyl #2”
 CF - “Misfire during warm-up, Cyl #3”
 D0 - “Misfire during warm-up, Cyl #4”
 D1 - “Misfire during warm-up, Cyl #5”
 D2 - “Misfire during warm-up, Cyl #6”
 D3 - “Misfire during warm-up, Cyl #7”
 D4 - “Misfire during warm-up, Cyl #8”
 D5 - “Misfire during warm-up, multiple cylinders”
 D6 - “PreCat oxygen sensor slow response, Cyl #1-4”
 D7 - “PreCat oxygen sensor slow response, Cyl #5-8”
 D8 - “PreCat oxygen sensor slow switching (rich to lean), Cyl #1-4”
 D9 - “PreCat oxygen sensor slow switching (rich to lean), Cyl #5-8”
 DA - “PreCat oxygen sensor signal size/amplitude, Cyl #1-4”
 DB - “PreCat oxygen sensor signal size/amplitude, Cyl #5-8”
 E4 - “Drive-by-wire throttle control failure”
 E5 - “Drive-by-wire throttle control failure”
 E6 - “Drive-by-wire throttle position failure”
 E7 - “Control unit self-test, slave processor check”
 E8 - Evaporative emission purge valve functional check
 F7 - VANOS pressure accumulator valve
 F8 - “Intake camshaft VANOS moving time, Cyl #1-4”
 F9 - “Exhaust camshaft VANOS moving time, Cyl #1-4”
 FA - “Intake camshaft VANOS sealing, Cyl #1-4”
 FB - “Exhaust camshaft VANOS sealing, Cyl #1-4”
 FC - “Intake camshaft VANOS moving time, Cyl #1-4”
 FD - “Exhaust camshaft VANOS moving time, Cyl #1-4”
 FE - “Intake camshaft VANOS sealing, Cyl #5-8”
 FF - “Exhaust camshaft VANOS sealing, Cyl #5-8”
		|  21.07.2011, 23:53 | #3 |
	| Erfahrenes Mitglied
 Habe in einem 5er Forum dies gefunden:
 "D7" means the left hand fuel tank syphon pump is BAD. The "81" appears on all our cars with a D7. And, the "254" is a countdown counter that counts the number of engine starts (or key activations) since it was posted. It will eventually get to "000" and stay there until the dealer clears it.
 Bei der Tankanzeige hatte ich die Tage 0/13/13L... ich wollte ihn jetzt etwas leerer fahren und habe nun 0/4.8/4.8L.
 Was ich nicht verstehe ist, um welche "syphon pump" handelt es sich? Was soll ich unternehmen?
 Zusätzlich habe ich auch diese Liste, falls sie jemand brauchen sollte:
 1 Fuel consuming signal from engine control unit faulty
 2 Fuel consuming signal (ti-II) from engine control unit faulty
 3 Road signal from ABS/ASC/DSC control unit faulty
 4 RPM (tD) from engine control unit faulty
 5 Coolant temperature sensor faulty
 6 Temperature sensor
 7 Outside temperature sensor
 8 Fuel level sensor 1 (Fuel pump side)
 9 Fuel level sensor 2 (without fuel pump)
 10 Tension to high at the power supply
 11 EGS signal disturbed
 12 Power supply Pin 15
 13 Power supply Pin R
 14 Service Interval Display (SAI) Reset
 15 Pressure Switch
 16 Gong Sound (T1)
 17 Gong Sound (T2)
 18 Gong Sound (T3)
 19 Current to high in the instrument cluster
 20 Internal error in the LCM module
 21 Internal error (IKE)
 22 Vehicle speed signal (Tacho-A)
 23 Instrument cluster -Bus (I-Bus)
 24 Body-Bus (K-Bus)
 25 Error during activation of the instrument in the instrument cluster
 26 Undefined error
 27 Internal Error
 28 I-BUS error
 29 Power Supply
 30 Power Supply
 31 Power Supply
 32 Power Supply
 33 K-BUS
 34 Oil Pressure Control Light
 35 Reverse gear recognition
 3E Error by activation display
 3F Instrument cluster current to high
 44 Oil pressure switch
 87 Body-Bus (K-Bus)
 88 (I-Bus)
 8B Gong Ton (T3)
 8C Power supply Term. R
 8D EGS Data lead disturbed
 8F Power supply
 90 Power supply Term. 15
 91 Gong Ton (T2)
 92 Gong Ton (T1)
 BC Break fluid level
 BD Electronic break power
 BE LCM internal error
 BF Instrument Cluster Internal Error
 C1 ABS/ASC/DSC Signal(Tacho)
 C3 RPM signal from DME control unit
 C6 Output PIN 6 (Code EWS)
 C7 Fuel tank sensor 1 (fuel pump side)
 CD Fuel consumption signal DME 1
 CE Outside temperature sensor
 CF Service Interval Display (SIA) Reset
 D3 Coolant temperature sensor
 D5 Oil temperature sensor
 D7 Fuel tank sensor 2 (without fuel pump)
 DA Fuel consumption signal DME 2
 F0 CAN-Bus off
 F4 CAN Identification missing
 F5 CAN Identification missing (ASC)
 F6 CAN Identification missing (DME)
 F7 CAN Identification missing (DME)
 F8 CAN Identification missing (DME)
 F9 CAN Identification missing (DME)
 FA CAN Identification missing (EML)
 FB CAN Identification missing (EGS)
 FC CAN Identification missing
 FD CAN Identification missing
 Wenn ich sie richtig lese, dann ist mein Tanksensor links kaputt. Vielleicht erklärt das auch die Anzeige 0/13/13L (also linke seite angeblich leer).
 Kann man das Teil kaufen und ersetzen? Oder brauche ich einen neuen Tank für 800 Euro? :-)
				 Geändert von actano (22.07.2011 um 00:00 Uhr).
						Grund: Korrektur
		|  22.07.2011, 00:02 | #4 |
	| Erfahrenes Mitglied
 die Liste habe ich soeben aus meinem Beitrag gelöscht und eine andere, die mir besser gefiel, eingesetzt :-)
Weil bei "deiner" für D7 etwas anderes steht, als ich für plausibel halte...   |
		|  22.07.2011, 00:09 | #5 |
	| Erfahrenes Mitglied
 Hm.. hier sind man nur einen Füllstandsgeber links abgebildet:   RealOEM.com  BMW E38 730i Fuel pump and fuel level sensor  - Teil #6 und die Dichtung #7.
Anscheinend muß man das so kaufen?? Oder kann man nur den elektrogeber (oder widerstandgeber, was auch immer) ersetzen? Hat jemand das schon ausgetauscht gehabt?
Gruß |
		|  22.07.2011, 15:25 | #6 |
	| Erfahrenes Mitglied
Fahrzeug: E38 750i 10/95
 Jau, der Füllstandsgeber rechts sowie links ist jeweils EIN Teil.Das kann man ruhig neu kaufen oder halt bei einem der "Schlachter".
 Jedoch ist dann die große Frage, ob ein gebrauchtes Teil nicht auch (unbemerkt) Defekt ist.
 ... und viele Schlachter lassen diese Teile im Tank, den sie als ganzes verkaufen.
 Du kannst (bei ordentlich leerem Tank) das Teil ja mal losschrauben und mit der Hand "bedienen". Dann müsste sich ja die Tank-Anzeige relativ schnell ändern.
 Signatur:
		|  22.07.2011, 15:42 | #7 |
	| Durchputzer, kg CO²/km
 Hy,nur so nebenbei,der linke Tank-,bzw.hälfte,wird immer als erstes leer gepumpt,prüfe mal welche Mengen er schreibt wenn Du den Tank voll hast.
 Ab ca.40 Liter ist dann immer die linke Hälfte leer,beim Fahren,wenn er abgestellt ist gleichen sich die Hälften wieder aus und beim "Inbetriebnehmen" fängt das gleiche Spiel wieder von vorne an,alles von Links nach Rechts.
 Bei mir schreibt er auch irgendetwas vom li.Tankgeber gegen Masse,bei mir stimmen aber alle Angaben,egal ob im freigeschalteten Menü,als auch Tanknadel.
 Also,wenn alle Anzeigen passen,kannst Du den Fehler vergessen.
 Gruß aus Wien,grunzl
				__________________ Beim Beschleunigen müssen die Tränen der Ergriffenheit waagerecht zum Ohr hin abfliessen.
  Meine Alben
Besonderer Dank auch an:
BMW-Spezi in WIEN Fa.KARRER
 Oberlaaer Straße 230
 1100 WIEN
 Tel.:01/606 50 35
  http://www.karrer-kfz.at/ |
		|  22.07.2011, 18:40 | #8 |
	| Erfahrenes Mitglied
 Danke nach Wien. Ich habe die Erklärung (zuerst links, dann rechts) heute von einem BMW-Spezi auch gehört. Nun tanke ich voll und gebe Bescheid. |
		|  22.07.2011, 18:58 | #9 |
	| Born to run
Fahrzeug: E30, E36, E38, C4
					Zitat von actano  Danke nach Wien. Ich habe die Erklärung (zuerst links, dann rechts) heute von einem BMW-Spezi auch gehört. Nun tanke ich voll und gebe Bescheid. |  Echt, das war Dir neu ????   Klick mich |
		|  22.07.2011, 22:33 | #10 |
	| Mitglied
Fahrzeug: 760i E65 VFL, 530d touring E39 VFL, escort cabrio, 740i E38 VFL, 323i touring E36, 530i touring E34, 325i cabrio E36, 323ti compakt e36
 die "fehler" im geheimen menü sin für n *****. in meinem 5er stehen da 8 fehler, beim auslesen kommen keine. auch der    sagt daß die fehler nix zu bedeuten haben
mffg |
	|  Forumregeln |
 HTML-Code ist aus. |  |  |  |
