Alt 02.03.2015, 11:41   #31
Originale Felgen und Reifen drauf?
Advanced BMW ABS hints and tips
ENGINE APPEARS TO MISFIRE OR STUMBLE INTERMITINTLY
MODELS AFFECTED:
5 Series(E34), 7 series(E32), 8 series(E31) all equipped with ACS.
FAULT:
Under certain specific conditions an apparent engine misfire or bucking may occur. This is not an engine misfire.
CAUSE:
Short (less than 100 milliseconds) fuel injection cut-off, as a result of MSR (engine drag torque control) regulation. This is a normal ASC function that may occur under these conditions: -The vehicle is equipped with ASC -Vehicle speed between 45 and 60 MPH -A rough road surface (e.g. potholes, railroad tracks) -Light throttle(accelerator pedal only depressed 1/8) -ASC not switched off.
SOLUTION:
Replace the ASC control unit. no further diagnosis of the ABS/ASC system should be necessary.
ABS, ASC, AND ASC+T MALFUNCTION
MODELS AFFECTED:
All models equipped with ABS,ASC OR ASC+T
FAULT:
Any of the ABS ASC and ASC+T systems inoperative, intermittently inoperative, or illuminating the warning lamp.
CAUSE:
All BMW'S with slip control systems use 4 wheel speed sensors which monitor each wheels speed of rotation with a high accuracy. The system control unit uses this information to calculate a vehicle speed. In this way it detects wheel speed variation. If the inputs vary from each other by a certain amount, the control unit is not able to do the calculation reliably (plausibility fault) and takes its self off-line as a safety precaution(fail-safe).This can be because the wheels and tires are non-approved partsand therefore do not agree with the system.
SOLUTION:
Make sure the vehicle is fitted with BMW approved wheels and tires. Then do further diagnostic testing to check if fault is resolved.
Schon mal den Fehlerspeicher auslesen lassen, das ist am Ende billiger als nur auf Verdacht tauschen.
E32 750i testwerte- wo ist Wahrheit?? Arnoldo57 BMW 7er, allgemein 4 26.05.2005 22:15
does anybody have these 750i tests..? : Arnoldo57 BMW 7er, Modell E32 5 12.05.2005 19:50
750i E38 vs. 750iL E32.... nach 6 Wochen Erfahrung. ferri BMW 7er, Modell E38 0 23.03.2005 09:13
Schwächen 750i ClausV8 BMW 7er, Modell E32 2 08.05.2004 06:37
"Hintenachse" from 730i into 750i schnitzer BMW 7er, Modell E32 0 08.07.2002 20:52
Alle Zeitangaben in WEZ +1. Es ist jetzt 09:32 Uhr.
