BMW 7er, Modell E23 |
17.09.2005, 08:34
hat zuviel Alteisen...
Fahrzeug: 745iA BJ 03/86, 728iA BJ 02/83, 530d e61 Bj.04/06, 325iT e46 Bj.03
For the Oil Change you need 5.75 litres of oil(incl.filter change, you should change the filter). This also should stand in the owners manual. I don`t have tryed Würth cleaning fluid. I change my oil once a year or all 12 tkm, until today i have no problems with my engines, and i owned over 8 BMW`s until yet. The last BMW e34 535i i owned had run over 315tkm, and i sold the car with great running engine. I only use CASTROL Oil, prefered 10W40 or 10W60.
P.S. My English isn`t very well, i don`t use it for years.
 Hubraum statt Wohnraum !
17.09.2005, 10:27
Thanks  Your english is great, I understood every word  I dont have the owners manual. Do you use mineral or syntetic oil?
17.09.2005, 10:56
I usually use CASTROL RS 10W60 or CASTROL GTX 5 10W40, i also used CASTROL GTX 7 5W40, this oils are all synthetic. You also could use a 15W40 mineral oil. I prefer Synthetic oil, and i`ve never had problems with my engines.
17.10.2005, 20:25
Hello,
you don't need Racing Oil.
You also don't neet Racing Spark Plugs, oder Razing Foam....
Search for a manual, there you get all Informations.
Be careful when you refill the Power steering Fluid.
If you don't pay attention to the manual (RTFM...), there ist much too much Fluid in the System.
CU, Franz
