30.05.2005, 11:57
Fahrzeug: BMW 740d (E38)
TV - have you seen this before?
There's an interesting item sold on ebay - It looks like a pass-thru cable to enable TV. This looks interesting because it would be very easy to install, huh?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...777087085&rd=1
Has anyone seen this before? Does it work?
Pepaaa
30.05.2005, 13:05
Erfahrener Ahnungsloser
Fahrzeug: G31 540i, Z4 M40i
it works
hello prepaa,
yes it works... but if you have MK1 or MK2 you can have it cheaper: You can activate your Navi with onboard-switching. It also can be, that the onboard-activation works also for MK3. For MK4 it definitely does not work. Herefore you need this interface-cable. You will find the manuals for onboard switching at "Tips & Tricks".
30.05.2005, 13:16
Hi @pepaaa
It works... I installed this item!
Greetz
30.05.2005, 14:23
mine is MK3 and i don't think it can be unlocked. Or it probably can, but it is unknown ;-)
Guys, thanks for answering in English, I appreciate it :-)
Greetings!
Pepaaa
30.05.2005, 14:29
Unlock Mk3? No problem...
buy it, install it (5min.) and look at TV....
Greetz
30.05.2005, 18:44
Lewer duad üs Slav!
Fahrzeug: T4 VR6 - W210 E430
or install a mk2, unlock it, install the mk3 again and it stays unlocked. so did mine.
Hybrid-Darstellung
