hier der Bericht von IT Jedi aus USA und Fotos, er hat seinen E34 mit LEDs fuer Innenbeleuchtung, durch dem Umschalter in meinem Modul auf LED geht das auch
http://i839.photobucket.com/albums/z...i/ea3f942c.jpg
http://i839.photobucket.com/albums/z...i/ec4702ca.jpg
That installed with NO PROBLEMS
I have installed LED's for all my interior lights (Blueish-White for entry/exit and slightly warmer yellowish-white for map). They are bright. Really bright. So instant on and off was overly harsh.
Shogun's dimmer kit was easy to setup and took about 15 minutes to install. Most of that time was using Google Translate on the install page and re-re-reading the result. I'll write up the same instructions in English. Sadly it was all so fast that I only snapped two pics.
All the install bits come in the kit. Pliers, wire tool and a pry tool (I prefer the plastic kind vs a screw driver) are all that's needed. Soldering is optional but not needed. The kit is complete.
Top notch. And the results are outstanding. My fiancee described the improvement as more elegant and graceful.
This may not top many lists of import "fixes" but its a tremendous aesthetic upgrade.
Hier jetzt Seine Installationsanleitung in Englisch mit youtube, Beleuchtung mit LEDs ausgestattet
http://www.bimmerboard.com/forums/posts/816539
