21.02.2006, 13:44
#91
Fahrzeug: 750i E65 (11.2007)
Hier die Anleitung:
Steps:
1. Obtain correct Navigation CD image of S/W version (ie V26.09aNote: this version could be bad for your unit, V26, V25, etc...)
2. Load image onto PC
3. Locate "navboot" file. Usually located in \V_2\RR\0101\BMWC01S\app_sw\
4. Copy "navboot" to hard drive on PC
5. Using GifExtractor load "navboot" by clicking "Find" button
6. Once loaded, click "extract"
7. Now in the "found images" box highlight the first entry and using cursor scroll down to the image that you will change. Located at HEX address [b1f418] it's the fourth one down.
9. NOTE! the new splash image has to fit the screen so you'll have to edit it (with Paint, PhotoShop, etc...) by making sure that it has aspect ratio of Width 400 x Height 234 x Depth 8bit 96X96dpi, single frame. And saved as a *.GIF file
10. If the new gif image is larger than 4544KB then you'll need to check the box "Do not check file size"
11. Now select the gif you want to load by clicking at the bottom "Select image to exchange"
12. Voila!! now you have a new splash that will startup
Optional: If you want to change the S/W version that displays on the top right of your navigation display such as "4-3/60" (ie 4 is MIV system with S/W 60). And is found under menu->settings you can do that in the "New header text" box
Now to create the image:
1. Start UltraISO (you will see window split into four sections)
2. Goto File->Open (locate the Navigation CD image of S/W) or Open CD/DVD
3. Once CD is loaded into "Image" window navigate to \V_2\RR\0101\BMWC01S\app_sw\
4. Now goto Actions->Add Files and locate the modified "navboot"
5. You will be prompted to verify replacement. Select "yes"
6. Now you're ready to make the new ISO image. In the top left window labeled "Image", click the first entry (it will look like 20060220_120036 with a CD Icon) edit the line to reflect "NAV_SW" and press return
7. Goto File->Save as and name the file of your choosing with "file type" as "mdf,mds" if using Alcohol120, otherwise save type as *.ISO if using Nero, DVD Decrypter
8. Almost there!!!
Benötigt wird der Gif-Extractor, zu bekommen hier
Ultraiso ist über google zu finden.
Habe meinen Screen schon geändert
Für "Profillose" gilt: Ich antworte auf keine Frage mehr....
21.02.2006, 14:00
#92
Fahrzeug: F01-730d (09.13)
Logo ändern geht übrigens auch mit den anderen Version, es muß nicht die unsägliche V26.09a-Beta sein...
21.02.2006, 15:59
#93
Genau,
ich habe die V26 geändert und über die Beta gebügelt.
Im übrigen scheint die Beta doch einige Macken zu haben. Sie ist auch älter als die V26. Es scheinen schon einige Mk4 gestorben zu sein.
Deshalb habe ich die V26 drübergebügelt.
21.02.2006, 16:04
#94
Zitat von Profiler
Genau,
NÄ !!!! Scheiße, ich will das aber haben!!!! Bin gerade dabei, meinen MK3 zu verkloppen!
21.02.2006, 16:07
#95
Deshalb V26 wieder drüber, Birdview ist dann ja noch da, nur man darf die Ansicht nicht ändern, dann isset futsch
21.02.2006, 16:15
#96
Fahrzeug: BMW 530D
Zitat von Profiler
Hier die Anleitung:
Danke
Kann man jedes Bild einstellen
Gruß Martin
Dpf Umbauten
21.02.2006, 16:25
#97
Fahrzeug: 740iA
Zitat von mo740i
Danke
Zitat von RolandDV
HAllo,
Fuer allen die ihren Startlogo willen aendern hier einige Beispiele. Diese Dateien kann mann runterladen und in die Datei 'navboot' einspeisen mit den Program Gifextractor.
Die Bilders haben eine Groesse von 400x234 und 8-bit Farbtiefe und koennen mit Photoshop erstellt worden.
mfg aus Belgien, Roland
Meine Frage nochmal : Es geht nur bei MK3 und MK4 Richtig ?
Gruss Emil
Euer Emil hat euch alle lieb
Bin bis 21.04. in Osterferien!
21.02.2006, 16:27
#98
Fahrzeug: 750Il Highline bwj 10/98
Emil.
siehst du bei den MK1 oder MK2 ein start Logo
gr. Appy
21.02.2006, 16:30
#99
Gruss Emil
RICHTIIIIICH !
21.02.2006, 16:32
#100
Fahrzeug: 740iA
Zitat von appy
Emil.
gr. Appy
Antortet man auf eine frage mit einer gegenfrage
Natülich weisst du die Antwort auf deine frage
Aber meinst du jeder hat mit allen MK's zu tun wie du Appy
Ein einfaches JA hätte mir gereicht und anderen sicher auch, jetzt ist es sehr Kompliziert und man nuss den ganzen text lesen
Gruss Emil, der jetzt davon ausgeht, das es nur mit MK3 und MK4 geht und selber MK3 hat.
