Alt 05.02.2009, 10:27   #11
Andre628
Benutzerbild von Andre628
Fahrzeug: E32-750iL (10.91.), E23-735i Werkskat (03.85), G22-430i (02.21)
Hallo Erich,
den Hinweis hatte ich schon in einem alten Thread von dir gefunden.
Da haben wir gestern natürlich gleich nachgesehen. Der Stecker/Kontakt ist trocken und auch nicht korrodiert...
Danke dennoch
Die Lenkung (im Notlauf) geht heute übrigens noch schwerer als gestern...
Andre628 ist offline   Antwort Mit Zitat antworten
Alt 05.02.2009, 11:26   #12
Standard common power steering malfuctions
Because of exposure to underhood heat, high fluid temperatures, ozone, fleaxing, abrasion, grease, oil and road salt, power steering hoses should be replaced at least every 5 years.
When checking power steering hoses, watch for symptoms indicating the hose has deteriorated and should be replaced:
-hose is brittle or hard
With age the hose loses its ability to expand anc contract properly, and cracks appear. Exposure to excess heat (which "overcures" the rubber compounds) can cause this.
-hose is soft and spongy
A good sign that the hose has started to deteriorate inside. Oil and grease-soaked hoses are soft when squeezed, and should be replaced.
-exterior is worn
Caused by abeasion and contact with metal parts, thiscan eventually wear a hole in the hose, causing it to burst under pressure.
Remember hat not all power steering hose failures can be spotted by exterior signs. Hose can deteriorate from inside, causing small particles of the tube to flake off and be carried away in the fluid. These small particles can expensive damage to the pump, pump cylinder and other units.
Composite deteriorations are shown in the link on page 14.
Troubleshooting Guide:
Heavy Steering Effort
1. low on power steering fluid
2. loose rack piston
3. restricted fluid passages in gear assembly
4. bent or damaged rack assembly
5. internal fluid leakage in valve assy
6. external fluid leakge at pump
7. incorrect drive belt tension
8. external fluid leakage at hoses
9. incorrect engine idle speed
10. weak pump flow pressure
Hissing noise when parking
1, internal leakage in steering gear
2. steering wheel at end of travel (normal)
3. when turning steering wheel at standstill (normal)
Growl in steering pump
1. excessive pressure in hoses
2. worn cam ring in pump
3. scored thrust plates or rotor in pump
4. scored pressure plates
Swish noise in pump
defective flow control valve
Whine in pump
1. air in power steering fluid
2. low power steering fluid level
3. pressure hose or line contacting other parts
4. mis-aligned hose and line brackets
5. missing or damaged pump cover O-ring
Rattle in steering
1. pressure hose contacting another part
2. loose pitman shaft
3. lost pitman arm
4. loose tie rod ends
5. loose rack and pinion mounts
6. loose steering gear housing bolts
7. loose steering gear adjustments
Car wanders to one side
1. incorrect front wheel allignment
2. unbalanced steering gear valve
3. loose tie rod ends
Steering wheel surges or jerks
1. low power steering fluid level
2. loose pump drive belt
3. weak pump pressure
4. stickingflow control valve
Excessive play in steering wheel
1. air in hydraulic system
2. incorrect steering gear adjustment
3. loose steering gear coupling
4. loose steering shaft universal joint
5. faulty rotary valve
Increased steering effort
1. slipping pump drive belt
2. internal pump leakage
3. low power steering fluid level
4. too low engine idle speed
5. air in hydraulic system
6. weak pump output
7. malfunctioning steering gear
Poor return of steering wheel
1. maladjusted steering wheel
2. dry ball joints or linkage joints
3. binding ball joints or linkage joints
4. incorrect front wheel alignment
5. maladjusted hweel bearings
6. kinked return hoses
7. internal pump leakage
8. contaminated power steering fluid
9. mis-aligned steering gear to steering column
10. tight steering shaft bearings or bushings
11. bent or damaged rack
12. sticking or plugged spool valve
This of course does not all fit for our system, but most of it. >30 pages of education from
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) The world's most trusted name in belts, hoses & hydraulics | Gates Corporation Gates Auto Education
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.gates.com/common/download...n/428-7172.pdf
Alt 05.02.2009, 14:34   #13
Andre628
Danke Erich. Da haben wir ja was zu tun.
Muß aber warten. Mir hat es nämlich gerade den Kühler zerlegt glaub ich! Dampft schön vor und hinter dem Kühler und im Motorraum einiges naß
Gut, dass ich es gleich gemerkt habe, blöd dass ich nicht mehr bis zu meinen Schrauber nach Chemnitz komme
Ach ja, mit alten Autos wird es eben nie langweilig...
André
Alt 05.02.2009, 15:39   #14
Das meiste an den Punkten kannste ja so abhaken, viel bleibt nicht ueber, zum Beispiel alte, verengte Schlaeuche, oder Schlaeuche mit einem Knick,
ich wuerd als erstes mal in die Richtung suchen.
Alt 25.02.2009, 20:01   #15
Andre628
So, nach langer vergeblicher Fehlersuche habe ich den Dicken beim Bosch-Dienst abgegeben.
Natürlich nicht ohne (dort gewünschtes) Forumswissen im A4-Format
Fazit: die Jungens sind sehr eifrig und engagiert (E30 und w126-Fahrer ) und haben
den ganzen Nachmittag geprüft und gemessen. Bisher ohne Ergebnis...
Mechanisch ist soweit alles okay. Auch Lenkgetriebe, Servopumpe, Schläuche etc. sind nicht auffällig.
Die Jungs tippen auf ein Elektronik-Problem! Tachosignal und Servotronic-Steuregerät sind okay.
Was fehlt sind Vergleichsdaten um die verschiedene Messergebnisse auszuwerten.
Also welche Werte müssen/sollten am Wandler ankommen, an der Pumpe, Druckspeicher etc. pp.
Daher: Ich suche dringend Messwerte/Solldaten der elektronischen Komponenten im Bereich der Servotronic!
Ganz besonders haben Sie mich um einen Schaltplan der Servotronic-Komponenten gebeten.
Ich werde gleich noch im WWW (speziell in Japan ) forschen, aber wenn Jemand Material bei der Hand hat,
wäre ich für eine Info dankbar.
Nachtrag: Schaltplan habe ich auf Erichs Seite gefunden.
Nun fehlen noch Messwerte
André
Geändert von Andre628 (25.02.2009 um 20:47 Uhr).
Alt 04.03.2009, 21:29   #16
Andre628
Hier die Auflösung des "Rätsels" :
Tatsächlich war der Wandler am Lenkgetriebe der Übeltäter!
Nachdem tagelange sämtliche Schläuche geprüft, die Servopumpe getestet, alle elektrischen Leitungen und Bauteile durchgemessen und Signale geprüft wurden, gab es letztendlich nur noch diese Option. (obwohl der Wandler anfangs auch als i.O. galt)
An dieser Stelle ganz besonderen Dank an @Erich
André
Alt 05.03.2009, 00:09   #17
Die Junx werden wohl gestaunt haben, als Du ihnen die Lektuere mit den Diagramme gezeigt hast von mir
Alt 05.03.2009, 20:01   #18
Andre628
Au ja, die Augen wurden riesengroß. Die Jungs waren echt baff
Sie meinten, die haben bei Bosch keinerlei Möglichkeiten an solche Materialien heranzukommen und waren dementsprechend interessiert und dankbar. Eigentlich unglaublich. Wie wollen die denn gescheite Diagnosen erstellen und ordnungsgemäß reparieren... nach dem Motto trial and error?
Na egal, es funktioniert. Dankeschön
Ich versuche die Tage mal noch die dort gesammelten Messwerte in Erfahrung zu bringen. Der ausführende Mechaniker ist/war nicht da.
André
Alt 05.03.2009, 21:38   #19
Spongebob7er
Immer was neues......
Benutzerbild von Spongebob7er
Fahrzeug: BMW Touring E36 Edition 316i
Standard Mein Gebiet
Freut mich das alles wieder läuft.
Aber du sagst, wenn du den Stecker zusammen steckst im Fußraum, Notprogram????
Was passiert, wenn du den Stecker zusammen steckst?
Du überbrückst damit die Steuereinheit und gibst dem Wandler unter dem Lenkgetriebe die volle Spannung.
Heißt im Klartext, die Lenkung sollte butterleicht gehen, leider auch auf der Autobahn, wo sie eigentlich schwerer gehn sollte.
Diese Möglichkeit benutzt man eigentlich, um herrauszufinden, ob die Steuereinheit im Fußraum defekt ist.
Aber so wie ich es verstanden habe, hat sich bei dir nichts geändert, als du gebrückt hast.
Ergebnis: Wandler verstopft, da dort ein super kleines Sieb verbaut ist(Was man leicht verlieren kann, wenn man den Wandler tauscht)
Oder Wandler defekt(Elektrisches problem), also tauschen.
Wie Erich schon sagte, mit neuen Gummis tauschen, da man bei BMW die Gummies nicht einzeln bekommt, sondern nur den kompletten Wandler.
Spongebob7er
Euer geplagter Spongebob7er
und ich wünsche noch eine gute Fahrt
Spongebob7er ist offline   Antwort Mit Zitat antworten
Alt 05.03.2009, 23:10   #20
Andre628
Jau, genau das war die Intention. Ich wollte zunächst die Funktion des Steuergerätes prüfen.
Vor kurzem habe ich nämlich ein neues (gebrauchtes) Steuergerät eingebaut, da das alte defekt war. Die Auswirkungen waren ähnlich --> Schwergängige Lenkung.
Genau. Und damit war das Steuergerät als Fehlerursache auszuschließen und die Probleme haben begonnen
Spongebob7er
Mir wurde von einem Problem am Wandler berichtet. Über genauere Informationen verfüge ich leider nicht. Jedenfalls wurde ein neuer Wandler (180 Euro) von BMW verbaut. Aber die Jungs haben mich um ein Feedback gebeten. Deshalb werde ich morgen nocheinmal vorbeifahren und nachhaken.
André
Fahrwerk: EML-Leuchten gehen nach wenigen Sekunden wieder aus... EDC kaputt? bauminho750il BMW 7er, Modell E32 1 24.10.2007 18:04
BMW 3er: Gehen die Dämpfer kaputt, wenn ich die Federbeine komplett lagere? DerArne Autos allgemein 3 01.09.2007 23:03
Was sind die meisten Sachen die kaputt gehen? Easyrider BMW 7er, Modell E32 2 29.11.2006 14:32
MK3 statt MK2: Kann was kaputt gehen? darcman BMW 7er, Modell E38 11 21.02.2004 14:01
Alle Zeitangaben in WEZ +2. Es ist jetzt 09:40 Uhr.
