12.07.2017, 21:40
#21
Fahrzeug: E32-750iL (BJ 02.92) E32-750iL HL (BJ 06.91) E23-735i (BJ 84)
Febi Lager hab ich jetzt auch.
Also ich glaub ich habs kappiert
Nr. 10 mit nem Abzieher runter ziehen? Und Deckel Abschrauben. Könnte man gleich den Simmerring tauschen.
Die Mutter und Sicherungsblech Nr.11 u.12 neu. Die Schrauben der Kardanwelle auch?
Was ist denn eigentlich der Unterschied zwischen 4hp22 und 4hp24? Sind die gleich?
13.07.2017, 00:08
#22
Praktisch nur das Gehaeuse ist gleich bei beiden Aussen, aber die Innereien sind teilweise anders, um das hoehere Drehmoment des M70 zu verarbeiten, hab hier eine englische Beschreibung:
There are numerous changes in the 24 , first off
Springs with different rates are incorporated, next the torque converter diameter is increased to 280 mm then the bearing surface of the torque converter is longer to take the stronger loads, the converter lockup clutch diameter is increased to 300mm, the transmission bell housing is larger due to the increased converter size, the a tranfer plate is 15 mm wider in order to accept the larger a clutch, the stator wheel shaft is now mounted with 6 countersunk screws for a tighter connection with the transfer plate, a new pump body was designed for the longer converter shaft bearing, the splines on the input shaft are longer, both sealing rings on the input shaft are cast iron, the a clutch has a larger diameter and the clutch friction surfaces are increased in size also, the number of plates in the b,c and d clutches was increased by one in each,the one way clutch for 2nd gear has been stenghtened and riveted together, the oneway clutch for 3rd gear was changed from a roller type to a locking body type for greater torque, the planetary gear for 4 is much stronger now with forged webs, the output shaft diameter is increased and 2 holes are provided for more lubrication, the output flange has a larger bolt circle to take more force, the pan is deeper, the filter is different for the deeper pan.
Wandler vom 24 ist groesser, Glockengehaeuse ist groesser.
Schrauben der Kardanwelle benutzen wir immer die alten.
Hat er das nur angehängt wegen der Antriebskraft?
Zum Testen, ob sich was veraendert, genau so wie der andere es gemacht hat, um festzustellen, ob sich das Getriebe bewegt,
13.07.2017, 10:23
#23
Super. Danke Erich.
Also könnt ich ein 4hp22 kaufen und den letzten Deckel mit der Aufnahme fürs Getriebelager an mein 4hp24 bauen?
Würde eins billig bekommen.
13.07.2017, 10:38
#24
Vergleich vorsichtshalber noch mal die Teilnummer von dem Deckel von einem E32 750 4HP24 und dann ein 735 4HP22, nur um sicher zu gehn, dass es passt oder nicht BMW Teilekatalog
13.07.2017, 11:52
#25
Teile.Nr. ist gleich das freut mich,
kostet in BMWfans.info schlappe 367€ nur der Deckel und die Seite ist noch nicht auf den neuesten Stand.
also wer ein 4HP22 braucht meldet sich,
13.07.2017, 21:00
#26
Fahrzeug: `92 e32 750i Lachssilber, teilindividual ,'99 Passat 2,8 V6 4 Motion,´91 MB 500SL,`93 MB 500SEC, i
Zitat von Erich
Ich soll das geschrieben haben
Kann mich garnicht daran erinnern
Komm Erich nun gib es zu, das war doch am 23.11.2005 um 2:43 Uhr japanischer Zeit
...die Banker sind nicht so schlau wie sie glaubten,aber so gierig wie befürchtet..
...nichts auf dieser Welt ist so gerecht verteilt wie der Verstand-ich kenne niemanden, der behaupten würde,davon zu wenig zu besitzen..
14.07.2017, 15:51
#27
Die Schrauben der Kardanwelle verwende ich auch immer wieder. Sind aber Feinripp-Schrauben, soweit ich mich entsinne. Deshalb sagt der TIS erneuern. Die Muttern erneuere ich jedes Mal nach dem Lösen.
Den Flansch hinten am Getriebe kann man einfach so abziehen?
19.07.2017, 15:23
#28
Hi.
also ich hab die Mutter gelöst, den Flansch konnte man mit der Hand abziehen, ging sehr leicht, aber es kam ein bisschen Öl mit raus.
22.07.2017, 20:57
#29
Und den Simmerring kann man dann auch ganz easy wechseln?
25.07.2017, 12:06
#30
wäre jetzt auch meine Frage, wollte den auch gleich machen.
den alten rauszubekommen ist das wenigste Problem,
mit was kann man den am einfachsten einbauen? mit dem Gummihammer langsam rundum reinklopfen ?
