Alt 01.11.2011, 13:26   #131
Standard "THANKS, SHOGUN, you're a legend"!
kopiert von Bimmerboard:
My '89 E34 525i developed an alarm problem 4 years ago when the alarm horn was bipping intermittently whilst driving & it got worse over the next 2 years. During a routine dealer maintenance the car wouldn't idle unless (any) door was open. (Door pressure switches are original). Dealer finally suggested the front most module under the rear seat was faulty=GM. (This module operates the sunroof/electric windows etc. & all work perfectly).
Module was tested (independently)... "no prob". I eventually replaced it with another 2nd hand one & it went good for 2 years. Now the problem is worse, & as before, only when the car is at full operating temperature, so even after a few miles it starts to bip & the engine will cut momentarily. Whilst driving it beeps on & off & hazard lights flash... not good to drive around town... or anywhere.
ALSO, whilst still hot, & the car left parked (locked or unlocked), the alarm will suddenly go off. Opening any door/trunk will stop it, but it commences again as soon as the door is closed. Turning the key in the door lock several times will sometimes stop the alarm when the door is eventually opened. BUT SOMETIMES... the alarm will sound WHEN AN UNLOCKED DOOR IS OPENED!!! (Confused so far... yep, so am I). Otherwise, leaving a door/trunk opened until the car cools down seems to eventually stop the alarm from sounding, then it will sit for days without a murmur! Yesterday after a trip, whilst it was sounding... I removed the module & the alarm kept sounding! I've owned the car for 17 years, & there's no immobiliser that I know of. For further confusion, fitting the 'offending' module to another car it works perfectly!!! The dealer can't find a prob & 2 X INDEPENDENT AUTO ELECTRICIANS, DITTO.
Am I up for a new module? Or could it something else?
daraufhin hab ich ihm folgenden Tip gegeben:
crash alarm relay?
pull the crash alarm module in the fuse box and drive around and see what happens. The brown one, crash alarm geber is written on it, you cannot miss it
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) page_2
I had a problem that my hazzard lights came on by their own, it was also this relay. And read this
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Emergency flashers blinking when opening door
operation of crash alarm
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) operation of crash alarm
copied from the net:
Self activating flashers
Self-activating flashers. An owner of a 1993 BMW may complain that the emergency flashers come on by themselves and can't be shut off with the flasher switch. BMW says this may be caused by a bum transistor in the crash control module, which you need to remove. It's a tall brown case stamped with the words "Crash-Alarm-Geber." Check the manufacturing date stamped on the side in white. The first digit of the code indicates the year ("3" means 1993). The second and third digits indicate the week of manufacture (for example, "08" means eighth week). If the unit was built before the eighth week of 1993, replace it. Use Part No. 61 35 1 384 761 for 318i, 318iS, 325i and 325iS models. Use Part No. 61 35 1 384 732 for the 525i, 530i, 540i, 740i, 740iL, 750iL, 840Ci, 850Ci and 850CSi.
Antwort nach 1 Tag, Problem erledigt!
As I sit on my veranda with a cold beer, I raise the can & mutter, "Here's to the 'bimmerboard" before each sip!
Would indeed appear to be the relay. Before starting the car I removed the relay, looked at it & replaced it, & let the car idle for 20 minutes.... no prob so far. Went for a 50 mile drive... NOT a 'beep"! Returned home & removed it again & gave all 9 pins an emery rub & went for another drive. On return opened & closed all doors, locked & unlocked the car etc...
Now I write to say "THANKS, SHOGUN, you're a legend"!
Dirty contact could have been the problem but I'll replace the original one anyway.
Alt 07.08.2013, 16:28   #132
wie man das Crash Control Modul temporaer bruecken kann zum Testen, ob die Fehler dann weg sind, hier ein Bild aus einem E34
Alt 07.08.2013, 16:57   #133
Markus525iT
Es gibt dafür auch eine Brücke von BMW - die kann man anstelle des Alarmgebers verbauen.
Danach funktioniert alles wie gewohnt - bis auf die DWA Quittierung (Blinker, evtl Fernlicht)
Diese Brücke wurde immer verbaut, wenn keine DWA an Bord war.
Der Crash-Alarmgeber ist dafür zuständig, dass die Blinker und das Fernlicht aktiviert werden, wenn die DWA Alarm schlägt (oder geschärft/entschärft) wird.
Es gibt 2 Versionen, einmal ECE (nur Blinker) und US (Blinker und Fernlicht)
Markus
Alt 26.11.2014, 14:45   #134
Dieses Relais, Verbindungsstecker, Brücke, wurde aber nie im E32 verbaut.
E34 E36 Z3 BMW 1391725, BMW Teilenummer: 61351391725
Teil 61351391725 (Verbindungsstecker mit Verrastung) wurde in folgenden Fahrzeugen gefunden:
E34: 518g, 518i, 520i, 524td,525i, 525ix, 525td, 525tds, 530i, 535i, 540i, M5,
E36: 316i, 318i, 318is, 318tds, 320i, 323i, 325i, 325td, 325tds, 328i, M3
Z3: Z3 1.8, 1.9, 2.0, 2.8, 3.0i, M
Alt 08.04.2015, 07:26   #135
Die seltensten Dinge passieren durch einen defekten Crash Alarm Geber.
Habe jetzt von einem Fall gelesen, da ging der Warnblinker an beim betaetigen des elektrischen Schiebedaches an einem E34.
Relais raus, gebrueckt wie in dem Bild oben, Spuk vorbei. Danach neues Relais eingesetzt.
Vor einigen Jahren hab ich in USA von einem Fall gelesen, da ging die WBA immer an beim Oeffnen der Fahrertuer. Auch das wurde behoben durch Reparatur des Crash Alarm Gebers (Relais). Auto war ein E32 750 in EURO Ausfuehrung aus Finnland.
Alt 04.03.2019, 02:38   #136
Bild update, Bruecke zum testen Interner Link) http://www.7-forum.com/forum/showthread.html?t=230907
Also langsam nervt mich mein S. Karre wirklich! KJ750IL BMW 7er, Modell E38 28 19.06.2004 09:32
Ruckeln beim anfahren Nervt? D.R.I.V.E.R BMW 7er, Modell E38 32 04.01.2004 15:47
E32 Bordcomputer nervt MarcoB12 BMW 7er, Modell E32 7 05.11.2003 21:03
Meine Auto Uhr nervt mich jede Stunde um XX:59 Uhr alphornblaeser BMW 7er, Modell E38 5 21.05.2003 08:31
Männerstimme Navi MK1 nervt theo BMW 7er, Modell E38 3 24.05.2002 12:09
Alle Zeitangaben in WEZ +2. Es ist jetzt 09:35 Uhr.
