Alt 05.04.2009, 15:23   #1
Maarten730
Fahrzeug: E32/730i- '87 (S38B36)
Standard General question + noise -> in the trunk
Guten tag Allen,
Mein Deutsch reicht nicht um dass nächste "problem" zu erzahlen....
When I push the throttle...there is some noise coming "out of my trunk"
How can I describe it...like "rattling" from the fuel pump (I think this is underneath the black lid next to right of my spare tire).
Anybody an idea how to fix this problem?
Another question:
In the trunk...just rear the backseats...there is almost the entire width of the trunk... of a compartement covering with thick foam".
At this moment I am putting noise absorption plates in the car.(for my Sub)..do the holes in this compartement (about 8) have any use ?
Or should it not be a problem to cover these holes with the noise absorption plates ?
Hope to hear from you...as always...
Maarten.
Maarten730 ist offline   Antwort Mit Zitat antworten
Alt 05.04.2009, 15:38   #2
peter becker
750i powered by ROTTALER2
Benutzerbild von peter becker
Hallo Maarten
Check your complete Drive Shaft, especially the Bearing Nr. 1 + 2 in this
Picture.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Drive shaft-cen.bearing-const.vel.joint
important is your Differential too
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Illustrations
Best regards
Peter
Alt 05.04.2009, 15:47   #3
The space in the trunk is for the control module for soft close, so if no soft close installed, the space is free, the other spaces were considered for a gimmick which never made it to the E32. = doors softclose.
So you can use that space, no problem.
Is the sound coming from the trunk? Then maybe yor fuel pump makes the noise, or it is not fixed inside the tank and floats around. Remove the cover in the trunk and check the correct position of the fule tank pump.
Alt 05.04.2009, 15:57   #4
Maarten730
Thanks Erich and Peter
Erich...do you have by any chance picture of how the fuel pump should look like ?
I am really not familiar with these things
MfG.,
Maarten.
Alt 05.04.2009, 16:00   #5
peter becker
Look here.....
Alt 05.04.2009, 16:03   #6
peter becker
Look here.....
and here a step by step ilustration.....
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Engine -- Fuel pump replacement
Unterschiede altes - neues GM (General Module) Erich E32: Tipps & Tricks 17 12.04.2010 16:10
Tuning: M5 Style Rear Trunk Lip Spoiler Wings greg38 BMW 7er, Modell E38 1 05.10.2005 15:26
General Lee bei mobile Artos Autos allgemein 4 25.03.2004 20:24
730d turbo(?) noise and lack of power Rik Gruwez BMW 7er, Modell E38 3 11.01.2003 11:31
Alle Zeitangaben in WEZ +1. Es ist jetzt 15:35 Uhr.
