Alt 24.11.2005, 18:56   #1
E65 UK
Standard dvb-t
sorry, i dont speak german.
does anyone know if this digital tv tuner has the same functions as an oem tuner and is it controlled by the buttons on the nav screen? Some tv tuners use the AV input.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://cgi.ebay.co.uk/ws/eBayISAPI.d...DME:L:RTQ:UK:1
E65 UK ist offline   Antwort Mit Zitat antworten
Alt 24.11.2005, 19:01   #2
StormRider
Lewer duad üs Slav!
Benutzerbild von StormRider
Fahrzeug: T4 VR6 - W210 E430
it seems to be completely what you want.
StormRider ist offline   Antwort Mit Zitat antworten
Alt 24.11.2005, 19:57   #3
E65 UK
so its defintly fully integrated with the bmw screen then?
Alt 24.11.2005, 20:03   #4
andreas1405
Benutzerbild von andreas1405
Fahrzeug: 740i (E38-M62, 9/99); BMW F650GS; BMW R 1200 R
Yes, it seems to be perfectly what you want - and on top, you can watch TV during driving, also if you are using a dvd-player at the AV-input....
greets,
Andrew
.... that's what they wrote in the description .....
andreas1405 ist offline   Antwort Mit Zitat antworten
Alt 24.11.2005, 20:23   #5
E65 UK
thank you, sorry for all the questions.
where in the description does it say that you change channel using the monitor buttons?
and is there any difference between this and the oem dvb-t tuner?
Alt 24.11.2005, 20:32   #6
StormRider
Lewer duad üs Slav!
Die Conexx DVB-T Single Tuner können mit diesem Interface über die BMW Boardmonitortasten gesteuert werden.
it means the tuner can be connected via an interface by the original buttons.
(Boardmonitortasten).
Alt 24.11.2005, 21:15   #7
E65 UK
thanks, is the interface that is mentioned included or is that seperate?
Geändert von E65 UK (25.11.2005 um 13:53 Uhr).
DVB-T Tuner günstig und gut -> selber einbauen ! darcman E38: Tipps & Tricks 79 04.02.2015 18:39
Innenraum: DVB Tuner nachträglich einbauen ? UY10 BMW 7er, Modell E65/E66 17 03.11.2005 21:21
Elektrik: DVB T TV Tuner fisher BMW 7er, Modell E38 12 16.06.2005 09:24
Elektrik: DVD drinnen - DVB übrig hanmeiser BMW 7er, Modell E38 1 19.03.2005 07:23
Elektrik: Original DVB Nachrusten alphornblaeser BMW 7er, Modell E38 1 14.07.2004 20:11
Alle Zeitangaben in WEZ +1. Es ist jetzt 05:49 Uhr.
