Alt 27.10.2011, 14:12   #11
76 -90 MHZ ist Standard fuer Japan fuer UKW.
Bei der E32 Serie wurden alle E32 nach Japan ohne Radio ausgeliefert, in Japan wurden dann Sony eingebaut in Japanausfuehrung, diese lassen sich nicht umstellen auf EURO Frequenzen.
Dann habe ich einen E36 M3 aus 02.1998 aus USA, der tat es auch nicht hier in Japan. Wieder andere Frequenzen.
Hier was dazu:
Second-hand automobiles imported from Japan contain a radio designed for the Japanese FM band, and importers often fit a "converter" to down-convert the 87.5 to 107.9 MHz band to the frequencies that the radio can accept. In addition to showing an incorrect frequency, there are two other disadvantages that can result in undesired performance; the converter cannot downconvert in full the regular international FM band (up to 20.5 MHz wide) to the only 14 MHz-wide Japanese band (unless the converter incorporates two user-switchable downconvert modes), and the car's antenna may perform poorly on the higher FM band. Also, RDS is not used in Japan, whereas most modern car radios available in Europe have this system. Also the converter may not allow pass-through of the MW band, which is used for AM broadcasting. A better solution is to replace the radio and antenna with ones designed for the country where the car will be used.
Australia had a similar situation with Australian TV channels 3, 4 and 5 that are between 88 and 108 MHz, and was intending to follow Japan, but in the end opted for the western bandplan, due to CCIR radios that entered the country. There were some radios sold in Australia for 76 to 90 MHz.[7]
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) FM broadcast band - Wikipedia, the free encyclopedia
Im M3 war ein BMW Business car radio C33,Model: AL6BDU
hab jetzt eins aus D importiert, CD 43, das laesst sich auf einige Bereiche umstellen.
Alt 28.10.2011, 05:40
Rdecode
Dieser Beitrag wurde von Andimp3 gelöscht. Grund: Der Benutzer möchte offensichtlich nur seine Dienstleistung verkaufen. Hat mit dem Thread überhaupt nichts zu tun.
Alt 28.10.2011, 07:39   #12
Hammer
Fahrzeug: E38 L7 (2001)
Bezugnehmend auf den CD Wechsler:
Sollte doch auf Sicherung 69 liegen, oder?
Anyway, die ist heil und die Sicherung direkt am Wechsler ist auch heil - aber der Stecker mit den dazugehoerigen Kabeln war hin. Gefixt und nun laeuft der Wechsler wieder
Danke fuer die Hilfe / Ideen!
Und zum Radio-Thema:
Werde dann wohl einfach eins aus D besorgen (BM24), damit sollten dann ja vermutlich alle Probleme behoben sein.
Hammer ist offline   Antwort Mit Zitat antworten
Alt 28.10.2011, 07:48   #13
Andimp3
Benutzerbild von Andimp3
Alle nicht - aber die mit dem Radio-Frequenzband sicher
Merke: ein 7er ist wie ne Beziehung - bekommt manchmal ne Delle oder nen Knacks, aber mit viel Liebe und Mühe, Hege und Pflege kann man viele Jahre seine Freude daran haben
Alt 31.10.2011, 08:05   #14
Hammer
So, habe nun einmal nachgeschaut, was fuer ein Radio wirklich bei mir verbaut ist (siehe Anhang).
Kann ich getrost ein BM24 (von ebay) einbauen, oder muss ich noch auf irgendwelche Details achten?
Mein derzeitiges (Japan) Radio ist ja von Alpine und das was ich "im Auge habe" ist ein Beckers.
Ich moechte ungerne 200EUR ausgeben um dann festzustellen, dass es nicht funktioniert...
Und noch eine Frage: Koennte man direkt am Radio ein AUX IN Signal anlegen, ueber das man z.B. einen mp3 Player / Iphone anschliessen kann?
Freue mich ueber eine konstruktive Antwort,
Gruss Hammer
Dateityp: jpg Radiobeschriftung verkleinert.jpg (95,3 KB, 19x aufgerufen)
Dateityp: jpg Radiopins verkleinert.jpg (97,9 KB, 13x aufgerufen)
Geändert von Hammer (31.10.2011 um 08:26 Uhr).
Alt 31.10.2011, 09:39   #15
Smartyy86
'The Perforator'
Benutzerbild von Smartyy86
Fahrzeug: Ka eF Zett
Also der Stecker ist der gleiche wie bei den europäischen Radios und ich wage zu bezweifeln dass es 2 kabelbelegungen für einen Stecker gibt. Also sollte funktionieren. Einzige Sache wäre eine evtl andere Antenne für einen anderen empfangsbereich, wobei ich darüber nicht ausreichend informiert bin.
Zwecks aux-in, klingt zwar doof aber, benutz mal die suche
Schlagwörter wären: cp600bmw, Zemex und dension.
Denke da findest du einiges Lesestoff
Smartyy86 ist offline   Antwort Mit Zitat antworten
Alt 31.10.2011, 11:14   #16
Hammer
So, Radio ist bestellt...
Bezueglich AUX-In hatte ich schon viel gelesen (SuFu). Dachte nur, es gaebe evtl noch eine einfachere Moeglichkeit, zumal ja auch viele Autos eine Aux-In Buchse zu haben scheinen.
Da wo in meinem Auto mal der Videorecorder war, liegen ja auch diverse Anschluesse, aber die scheinen tot zu sein...
Alt 31.10.2011, 11:50   #17
Bevor Du das Japanradio in den Muell entsorgst da nicht brauchbar, check mal, was der Versand billigst nach Japan kosten wuerde.
Eventuell haette ich da Interesse dran, da ich in Japan wohne, wuerde die Versandkosten uebernehmen, falls die nicht so hoch sind. Kannst mir ja eine
U2U schreiben.
Alt 31.10.2011, 12:03   #18
Hammer
Jupp, werde versuchen was herauszufinden bezueglich Versand.
Bin allerdings ab morgen erstmal fuer ein paar Tage in Deutschland unterwegs...
Alt 31.10.2011, 12:17   #19
rubin
Benutzerbild von rubin
Fahrzeug: JEEP GC4 WK2 CDR
HPCaesar dürfte seines auch noch vom L7-ECE-Umbau im Keller haben...
Alt 24.11.2011, 07:15   #20
Hammer
So, Radio und ich sind wieder eingetroffen.
Radio ist verbaut und ich geniesse den (normalerweise) gewohnten Radioempfang!
Der Austausch hat den erhofften Erfolg gebracht - Danke fuer die Tipps etc!!
Radio knarrt, wechselt einfach auf Radio, Display flackert denyyyo BMW 7er, Modell E65/E66 0 02.07.2010 22:21
HiFi/Navigation: Radio Kabelbaum wohin???Alles voll Radio passt nicht rein! MisterE38 BMW 7er, Modell E38 1 15.03.2009 19:37
Frequenzbereich der orig. Lautsprecher Schorsch BMW 7er, Modell E32 45 20.10.2008 16:50
Innenraum: Cd Radio passt das Radio vom e36 bj2000 auf den e38 cass. radio ? levko BMW 7er, Modell E38 2 07.03.2006 11:33
Elektrik: Frequenzbereich Radio ändern?? alphornblaeser BMW 7er, Modell E38 5 20.09.2005 03:12
Alle Zeitangaben in WEZ +1. Es ist jetzt 16:41 Uhr.
