Alt 05.05.2007, 09:56   #1
mole
Standard HELP!, cant turn off alarm after replacing battery
Hello fellow german 7series owners!
I hope you can reply in english cos my german is not so good
My problem is that after I took out the battery for a resharge and then put it back in the alarm went off. I cant turn it off.
I have tried with locking the doors with key and with the remote. I have two buttons on my remote.
I localized the horn for the alarm and pulled out the cable before my neighbours could kill me
I have checked all the fuses and they are ok.
I have no idea of what to do, I cant start the car
Its a 1994 730i
Mike from Sweden
mole ist offline   Antwort Mit Zitat antworten
Alt 05.05.2007, 10:33   #2
Crazy
Mitglied BMW7er-Club
Benutzerbild von Crazy
Fahrzeug: leider z.Zt. keinen 7er
Hello, welcome here
Following instructions:
- Open the door, take place on Your seat and close the door.
- Turn ignition key to position "1" and let it there for 15 minutes.
- While those 15 minutes do not open any door, do not touch the key, just wait.
After having done that, alarm should be turned off.
Greetz
Norbert
Crazy ist offline   Antwort Mit Zitat antworten
Alt 05.05.2007, 10:35   #3
mole
Thanks for fast reply Norbert
I think I did that but maybe I did something wrong
Im gonna try that again
Alt 05.05.2007, 10:38   #4
Crazy
Just wait 20 mins - maybe, its not that exact!
Greets again
Alt 05.05.2007, 11:31   #5
Crazy
Any results?
Alt 05.05.2007, 11:52   #6
mole
Thanks!
15 min with key in position1 turned of the alarm
The alarm does no longer go off when opening doors etc
The LED on the dashboard, o top of center does no longer light
BUT now I cant start the car
The board computer says PPPP
The remote key doesnt work either
Alt 05.05.2007, 12:49   #7
peter becker
750i powered by ROTTALER2
Benutzerbild von peter becker
hello
please look at page 62 in the following link, you find here a choice of
posibilitis, for the pppp error .
best regards
peter
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.e34.de/tips_tricks/bc/bc4.pdf
Alt 05.05.2007, 12:51   #8
mole
Thank you!
Im gonna do that
I really miss my car :(
I need it for work
Alt 05.05.2007, 15:16   #9
mole
Well it looks like the drive away protection is activated or I have no clue what it is
I cant make the engine run
Alarm is off, remote key doesnt work
Anyone know how to make the car run?
Alt 05.05.2007, 15:50   #10
Crazy
Remote key must be re-initialized - read instructions manual. I can't instruct You here, because Your car is newer than mine and the remote initialisation has changed from 1991 to 1994.
The "pppp" should - as it does here - go within some minutes, if u set ignition to "on" and let it there for a while. Then it should be possible to enter time/date. Try sometimes to push "time/date"-button - if You see "----" its ok again.
After that it should also be possible to start the engine.
If not so, check car battery pack - maybe its low voltage!
Greets Norbert
Geändert von Crazy (05.05.2007 um 15:56 Uhr).
E65 730d couldn't turn on (problem no oil in fuel tank) arturro1982 BMW 7er, Modell E65/E66 14 15.02.2007 10:54
alarm.. EmilC BMW 7er, Modell E38 3 24.07.2005 13:28
Elektrik: battery drain - eine Sammlung von Daten Erich 7er, allgemein: Tipps & Tricks 0 27.01.2005 05:15
alarm h.rausch BMW 7er, Modell E38 3 20.01.2003 13:26
Alle Zeitangaben in WEZ +1. Es ist jetzt 15:32 Uhr.
