04.10.2007, 02:13
Fahrzeug: E39,E34
Problem mit memory-sitze
(E34 540ia -93)
The right back of the driver's seat doesn't go down, left goes down (motor works) and the whole seat is about to crack.. also the headrest doesn't go up or down, but the electronic motor works fine. Manual adjustment is possible for the headrest.
Electric seat with memory, any help please?
04.10.2007, 02:38
Looks like you have the socalled seat back twist, here some instructions how to shorten the cable
http://www.pagaduan.org/bmwe32/Fahrersitz.htm
English, nice info from Winfred for E34/E32
http://bellsouthpwp.net/m/i/miales/seatcablesfix.htm
Also go to my website below, on the link to Gale there are more instructions about seat back twist, seat back motor, and also how to change the gear of the seat.
Headrest: pull the headrest once more out and then push it in again, it seems that the 2 brackets of the headrest are not fully set into the gear of the system.
04.10.2007, 18:26
Fahrzeug: E39,E34
Thank You!
Repaired it and everything started working as new!!
05.10.2007, 03:36
Fahrzeug: E39,E34
Is it true that the electric motor and the mechanical parts to the electric lumbar support is already on this comfortseat?
http://www.gunnar525.de/screwings_be...e_e_einbau.pdf
I saw that blue connector hidden in the seat..
