Alt 06.08.2010, 20:27   #1
McTube
Benutzerbild von McTube
Fahrzeug: S50B32
Zitat von Glacier Beitrag anzeigen
But there aren't any : No
Do not ever overestimate diagnostics. There is a bunch of things it will not see, but an experienced mechanic will....so I agree with the above answers.
Alt 08.08.2010, 15:18   #2
Glacier
Benutzerbild von Glacier
Fahrzeug: E38 - 740i (02/2000)
Yes, you are probably right.
The air intake manifold gaskets were done at the same time as the PCV valve, and I checked for vacuum leaks by spraying brake cleaner all around the engine to see if there was a change in the idle........nothing.
When I tried to reset the adaptions there was a message saying "Module not responding". Even so, I have driven about 300 miles since the re-timing so I would have thought the DME would have learned the adaptions by now.
I wonder if there is a burnt valve or something?
Oh well, I'll keep trying to find what's wrong and will report back if I find anything.
Many thanks again for all your suggestions.
Glacier ist offline   Antwort Mit Zitat antworten
Alt 17.03.2011, 18:04   #3
macgyver52
Stan
Fahrzeug: F01-750i (06.09)
Hi Glacier,
it looks like i have the same problem with my 740i.
It also has the startup rattle, but i try to ignore it until it gets worse.
The more annoying problem is the vibrating engine in the same rpm range.
Do you or anyone have a solution by now?
I checked nearly everything, but i can´t find the reason.
macgyver52 ist offline   Antwort Mit Zitat antworten
Alt 19.03.2011, 12:15   #4
Glacier
Hi Stan,
not sure but, I think the startup rattle is caused by the oil draining from the vanos units, No.1:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i timing gear timing chain top - VANOS
When I changed the the two units I also changed the oil check valves, No.8:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i Cylinder Head Attached Parts
So, I'm not sure if it was the check valves, vanos units or a combination of both that cured the startup rattle. The vanos units change certainly fixed the ticking/tapping diesel-like noise
I did as 'Memyselfundich' suggested and got myself INPA. Here are some live data pictures of the cylinders:
I'm not sure what all that means so, maybe some of you German experts could confirm that they don't look too bad. Or do they seem not to be very well synchronized?
Now.......... I have been doing more investigating and I found that these parts on the nearside rear wheel have some play in them, No.2 & 5:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i REAR AXLE SUPPORT/WHEEL SUSPENSION
When the wheel is rocked at 12 & 6 o'clock there is about 1/4 inch movement. Nothing at 3 & 9 o'clock.
So, I have come to the conclusion that maybe I have been looking in the wrong place all the time! Most probably I did time the engine correctly and, by a crazy coincidence at that exact time, the rear balljoint started to make the car feel lumpy? And that's why I wasn't getting any fault codes from the engine.
Of course this is all guesswork until I have changed the offending parts. I may as well change the other rear bits too and I have got the parts from good old Ebay-de:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) REP SATZ QUERLENKER_HA 7ER E38 KOMPLETT 10-TEILIG NEU! on eBay (end time 14-Mar-11 13:00:40 GMT)
Waiting for this:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Advanced Keyword Product Search --- Sealey & Draper Tools - CCW-Tools
More expense!
I will report back on my findings.
Alt 19.03.2011, 16:20   #5
memyselfundich
Langstrecken Gleiter
The Rear axle parts are a piece of crap... they will be worn out in about 5000 kilometers..
The Idle doesn´t look tooo bad. just that they are off is bit strange, they should be the same.
What else have you replaced?
Alt 20.03.2011, 19:18   #6
Glacier
Two years ago I did the front end suspension arms with parts from ATP and they seem to be holding up ok, so I thought I'd get the rear parts from them too. Oh well, if they don't last, at least I'll know how to do it again then.
Besides the vanos units, I haven't replaced anything else.
Has anyone got any INPA live cylinder data to compare with mine?
Vanos im 735 740? Rainer H BMW 7er, Modell E38 8 02.12.2011 21:24
General question + noise -> in the trunk Maarten730 BMW 7er, Modell E32 7 05.04.2009 18:41
Motorraum: Vanos ? andromedar2000 BMW 7er, Modell E38 6 15.04.2007 22:37
VANOS o. Doppel-VANOS EXPERTEN gesucht JB740 BMW 7er, Modell E38 19 01.04.2006 20:57
730d turbo(?) noise and lack of power Rik Gruwez BMW 7er, Modell E38 3 11.01.2003 12:31
Alle Zeitangaben in WEZ +1. Es ist jetzt 05:54 Uhr.
