Alt 28.10.2016, 08:52   #11
Weisser "Qualm" ist ganz normal, speziell bei diesem Wetter und wenn er nur ab und an richtig heiss gefahren wird. Das ist Kondensation im gesamten Auspuff, der muss einfach mal richtig warm gefahren werden ueber 50 km und mal richtig heiss werden, damit das ganze Zeug innen mal wieder trocken wird.
Nicht umsonst sagen sie in USA zum 750 im Winter "Nebelwerfer".
Zu dem Thema verfaulte Eiergestank hatte BMW mal in USA extra eine Technische Info rausgebracht, auch Audi, hier mal teilweise kopiert:
ROTTEN EGG SMELL FROM CATALYTIC CONVERTER
The sulphur smell from the exhaust, is actually caused by running the engine/cat convertor slightly lean for long periods and then running under a rich condition (ie going up a hill under heavy load) This is when the sulphur smell (rotten egg) is produced.
Under relatively lean conditions, the sulphur found in gasoline is converted to sulphur trioxide, then during the rich running condition the sulfur trioxide is converted into hydrogen sulphide (rotten egg smell) within the catalytic converter.
Audi of America issued a service bulletin Group 24, #92-04 which detailed this problem. They list the cause as : the gasoline sulphur content and the characteristic of catalytic convertor to store sulphur compounds and release them during rich engine running conditions.
Switching gasoline brands may help. The Oxygen sensor may also need to be replaced to correct a fuel injection mixture problem.
Rotten egg smell- not a defective cat (von BMW)
On some vehicles, a sulfur smell or 'rotten egg' odor may be noticed coming from the exhaust system. The odor is usually noticed after a cold start, fast idle, extended periods of idling and full throttle acceleration. Sulfur smell is not an indication of an engine concern and will not cause reduced driveability or durability of the engine or any of its emission components.
The sulfur smell or 'rotten egg' odor is caused by high amounts of sulfur in the gasoline being used in the vehicle. Sulfur is normally eliminated during the refining process, but the EPA regulation of sulfur in gasoline differs from state to state. Vehicles using fuel containing high amounts of sulfur will most likely emit sulfur smell from the exhaust system.
When high sulfur fuel is burned, there is a chemical reaction in the catalytic converter causing the sulfur to oxidize. As the vehicle is driven, the oxidizing reaction odor in the converter will decrease with mileage and age. Replacing the catalytic converter will not eliminate sulfur smell and replacement will just extend the period of time needed for the converter to 'age' allowing it to reduce sulfur smell to an acceptable level.
1.Switch to a different brand of fuel and drive the vehicle for at least 100 miles. Monitor the decrease or increase in sulfur smell.
2.Do not add any type of 'fuel additive' as this could add sulfur to the fuel and cause/increase the odor.
3.Try to avoid extended periods of short trip driving or aggressive acceleration.
Geändert von Erich (28.10.2016 um 13:36 Uhr).
Alt 28.10.2016, 12:35   #12
Porsche-GT3
Back to the 80's..
Benutzerbild von Porsche-GT3
Fahrzeug: Audi A6 4G quattro, 750i E32 1990 und andere
Sehr interessant!!! Danke für die Antwort! 🖒
Porsche-GT3 ist offline   Antwort Mit Zitat antworten
Alt 28.10.2016, 20:52   #13
Aprilscherz
Benutzerbild von Aprilscherz
Fahrzeug: `92 e32 750i Lachssilber, teilindividual ,'99 Passat 2,8 V6 4 Motion,´91 MB 500SL,`93 MB 500SEC, i
..auch wenn ich nicht aktiv helfen kann, hab bei mir einen etwas 'alten' Geruch im Auto den ich gern noch etwas vermindern möchte es ist auch eine angenehme Ledernote dabei ,kann normal sein die Teppiche riechen dennoch etwas alt trotz nass sauger und trocknung.
..jedenfalls:
ich sitze auf dem Sofa,lese Erich'Post und denke mir:
Wahnsinn.einfach Wahnsinn wo und wie zeitnah und umfassend du hier aktiv versuchst wirklich JEDEM PROBLEM eines Teilnehmers beizukommen,
man muss es Dir,Erich einfach glauben/unterstellen dass du jedem so zu helfen versuchst als wäre jeder ein Freund der mit dir in der Garage schraubt,
GANZ großes Kompliment, durch Dich und natürlich weitere die immer hier am Start sind ist speziell das 7-Forum.com so außergewöhnlich und klasse.
Und freundlich(fast immer) und eben hilfreich.
Musste ich mal loswerden.
Ihr seid Top, ob Thomas,ich e32, haschra, camäleon,Norbi..rotti,ötti..sorry wenn ich nicht alle hier nennen kann !
...die Banker sind nicht so schlau wie sie glaubten,aber so gierig wie befürchtet..
...nichts auf dieser Welt ist so gerecht verteilt wie der Verstand-ich kenne niemanden, der behaupten würde,davon zu wenig zu besitzen..
Aprilscherz ist offline   Antwort Mit Zitat antworten
Crashtest E32 - Sicherheit im 7er Bucho BMW 7er, Modell E32 113 29.05.2024 13:52
E32 als erstes Auto? Wie wirds aussehen in 2 Jahren? Zlatko BMW 7er, Modell E32 39 28.08.2011 12:25
E32 Geheimnisse der Check Control (E32) Fanta E32: Tipps & Tricks 10 21.05.2007 16:42
Sitzheizung im E32 nachrüsten jak BMW 7er, Modell E32 12 18.03.2004 20:31
Pressestimmen zum E32 Christian BMW 7er, Modell E32 4 14.10.2002 10:21
Alle Zeitangaben in WEZ +1. Es ist jetzt 05:36 Uhr.
