Alt 06.08.2010, 16:28   #1
Glacier
Benutzerbild von Glacier
Fahrzeug: E38 - 740i (02/2000)
Top! VANOS noise fixed.......but another problem.
2000 E38 740i M62TU 04.04 101.000 MILES .
Hi, apologies for not speaking German .
I had the 'startup rattle 'and a noise the same as this video:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) YouTube - ‪M62B35 Ticking‬‎
After a lot of research, I concluded that it was coming from the VANOS units.
The E38 M62TU engine should not sound like a diesel .......... right?
So, I bought two new units , No.1 :
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i timing gear timing chain top - VANOS
And two new oil check valves , No.8 :
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) RealOEM.com BMW E38 740i Cylinder Head Attached Parts
Also the timing tools:
Here are the old VANOS units:
And the new VANOS units:
Now I am happy to report that the engine is nice and quiet, no more embarrassing tapping/knocking/diesel like noise. Also, no more startup rattle : Top
The problem is that the engine feels slightly ' lumpy '.
The idle is at 600 rpm and is steady. When the accelerator is pressed (car not moving) , there is a slight vibration up to 1200 rpm and then smooths out .
When driving along, at any speed, it feels like you are going over lots of ' bumps ', but the road is smooth.
I connected Carsoft V8.3 and there were no fault codes. I then took it to BMW for diagnostics ......... ........ same result no fault codes.
I tested for vacuum leaks ......... none .
Any ideas anyone?
Glacier ist offline   Antwort Mit Zitat antworten
Vanos im 735 740? Rainer H BMW 7er, Modell E38 8 02.12.2011 21:24
General question + noise -> in the trunk Maarten730 BMW 7er, Modell E32 7 05.04.2009 18:41
Motorraum: Vanos ? andromedar2000 BMW 7er, Modell E38 6 15.04.2007 22:37
VANOS o. Doppel-VANOS EXPERTEN gesucht JB740 BMW 7er, Modell E38 19 01.04.2006 20:57
730d turbo(?) noise and lack of power Rik Gruwez BMW 7er, Modell E38 3 11.01.2003 12:31
Alle Zeitangaben in WEZ +1. Es ist jetzt 12:39 Uhr.
