| BMW 7er, Modell E32 |   |
| Varianten |
| Detail-Infos |
| Interaktiv |
 |    - Anzeige -
		|  04.10.2007, 02:13 | #1 |
	| Neues Mitglied
Fahrzeug: E39,E34
				 Problem mit memory-sitze
 (E34 540ia -93)The right back of the driver's seat doesn't go down, left goes down (motor works) and the whole seat is about to crack.. also the headrest doesn't go up or down, but the electronic motor works fine. Manual adjustment is possible for the headrest.
 Electric seat with memory, any help please?
		|  04.10.2007, 02:38 | #2 |
	| Shogun
 Looks like you have the socalled seat back twist, here some instructions how to shorten the cable  http://www.pagaduan.org/bmwe32/Fahrersitz.htm
English, nice info from Winfred for E34/E32
  http://bellsouthpwp.net/m/i/miales/seatcablesfix.htm
Also go to my website below, on the link to Gale there are more instructions about seat back twist, seat back motor, and also how to change the gear of the seat.
Headrest: pull the headrest once more out and then push it in again, it seems that the 2 brackets of the headrest are not fully set into the gear of the system. |
		|  04.10.2007, 18:26 | #3 |
	| Neues Mitglied
Fahrzeug: E39,E34
 Thank You!Repaired it and everything started working as new!!
		|  05.10.2007, 03:36 | #4 |
	| Neues Mitglied
Fahrzeug: E39,E34
 Is it true that the electric motor and the mechanical parts to the electric lumbar support is already on this comfortseat?  http://www.gunnar525.de/screwings_be...e_e_einbau.pdf
I saw that blue connector hidden in the seat.. |
		 Linear-Darstellung |
	|  Forumregeln |
 HTML-Code ist aus. |  |  |  |
