Alt 21.03.2007, 13:15   #1
Standard wie Johan einen V12 tauscht - Bilder
Und noch ein paar Info dazu von ihm:
It took me one day to remove the front of the car, pull the old engine and install the new engine (not bad ey!?). And then another day to rebuild the front and hook everything up. And after all the trouble I went though before I'm not looking forward to doing it ever again. Just to give you an idea of what I went though:
-Removed the heads from engine 1
-Removed engine 1 because it was leaking badly
-Bought very cheap engine nr.2 resealed most of it to find it was pumping coolant into the oil
-Rebuild heads from engine nr.1 and put them on engine nr.2 only to find out the short block is probably cracked
-Bought and installed engine nr. 3 which seems to work OK. Still have to fix the temperature gauge to be 100% sure.
A couple of things I learnt:
-An 850 engine doesn't fit directly into the 750 without any mods. Some differences are: different alternator/oil lines/hydralic pump mount, different water pump, different aircon compressor mount, different input fuel lines,...etc.
-If you have to remove the engine from an e32 remove the front of the car as it saves so much time!
-You don't have to remove the entire exhaust and driveshaft
-The oil in your hair attracts sand...lots of sand!
-You can swap a M70 engine all by yourself
-people look at you very strangly if you buy 12 spark plugs at once
Now I still have to fix a crusher washer I forgot on the hydraulic pump which makes it leak really bad. And then it's MOT (OK the dutch call it APK) preparation time!
Alt 21.03.2007, 13:54   #2
J.J. McClure
Benutzerbild von J.J. McClure
Fahrzeug: ´91er BMW 730i M30, '95er Volvo 945 Turbo
Tja, wie heissts so schön:
Baura derfed des!
Schorsch
J.J. McClure ist offline   Antwort Mit Zitat antworten
Alt 21.03.2007, 17:51   #3
e32addicted
Der Salzmann
Benutzerbild von e32addicted
Fahrzeug: e32-750ia 735ila 10/88 Klima
Ich frage mich nur wie Johan immer die Frontbleche weg und vor allem
wieder hin bekommt, die sind doch verschweißt, oder???? . So wie er es macht d.h. ohne Frontblech für Kühlerbefestigung, Niere usw... ist es top, da hat er viel Platz und kann alles samt Getriebe rausziehen.
Jörn
FREUDE AM FAHREN!!!!!! "In Memory -Rottaler2-"
e32addicted ist offline   Antwort Mit Zitat antworten
Alt 21.03.2007, 18:36   #4
osl jaap
street-legal racer
Benutzerbild von osl jaap
Das ganze front blech teil ist verschraubt. Das kann mann einfach abnehmen.
Dateityp: jpg 65.jpg (48,9 KB, 53x aufgerufen)
Ciao,
Osl Jaap
Alt 21.03.2007, 18:55   #5
e32addicted
Der Salzmann
Hmm, da war ich wohl blind. Ich erinnere mich, dass ich und mein Kumpel
damals wie wild nach genau dieser Verschraubung gesucht haben, aber
nur Schweißnähte gesehen haben. Im Nachhinein ist das
Mir geht es speziell um das Teil Nr.7 hier konnte ich nirgends eine Verschraubung
sondern nur Schweißnähte finden.
Da ich an meinem kurzen 35 eine Motorüherholung mit Ausbau plane
kommt mir diese Info gerade recht
Vielleicht sollte ich doch öfters den ETK anwerfen.
Die Verschraubung von -7- ist für mich aus der Zeichnung auch nicht
ersichtbar, da muss ich nochmals suchen!!!!!!!!!!
Danke und Gruß
Jörn
Geändert von e32addicted (21.03.2007 um 19:05 Uhr).
Alt 21.03.2007, 19:20   #6
smiler78de
Benutzerbild von smiler78de
Fahrzeug: E65-730d (05.03)
@e32addicted: hab ma ein bild von meinem, sind unten vier schrauben (siehe kreise) und oben mit dem kotflügel sind auch noch zwei links und zwei rechts und dann kannst du ihn rausnehmen. naja, vorher mußt halt noch den anderen gedönst von dort wechnehmen.
Dateityp: jpg k_DSCF1950.JPG (56,3 KB, 69x aufgerufen)
Gruß Maik
(oo=00=oo)
Geändert von smiler78de (21.03.2007 um 19:24 Uhr). Grund: bild vergessen
smiler78de ist offline   Antwort Mit Zitat antworten
Wie tauscht man den ABS-Sensor beim E38? chrisee BMW 7er, Modell E38 24 09.04.2021 11:56
BMW 3er: Wie tauscht man die Standlichtringe aus?! FM111 Autos allgemein 0 23.01.2007 16:01
Karosserie: Graue Bilder und V12-Niere (Bilder) Erich M. BMW 7er, Modell E38 25 17.05.2005 07:27
Wie baue ich einen CD Radio in einen E38 ein? Vmax 730 BMW 7er, Modell E38 4 23.10.2003 10:07
735i / Wie tauscht man die Lambdasonde aus ??? schnuffi85 BMW 7er, Modell E32 11 05.04.2003 19:37
Alle Zeitangaben in WEZ +1. Es ist jetzt 14:30 Uhr.
