![](layout/start02.jpg)
![](layout/whitepixel.gif)
![](layout/shadow.gif)
![](http://www.7-forum.com/templates/images/e32klein.jpg) |
![](layout/start01.gif) |
![](layout/clearpixel.gif)
29.03.2007, 10:29
Fahrzeug: E36-93'
Pdc E32 From 8 To 4 Sensors
Ive read some mails about how to switch from 8 to 4 sensors.
Some one said pin 1 from X300 switch to 12V. I just want to CONFIRM the laid out.
PIN-Stecker-Benennung
1-X300-12V
2-X300-TXD
3-X300-
4-X300-
5-X300-RXD
6-X300-Tacho A Signal
7-X300-
8-X300-Gong PDC hinten
9-X300-Schalter PDC
10-X300-
11-X300-
12-X300-Masse
13-X300-Stromverteiler unter Rücksitz F31
14-X300-Signal Rückwärtsgang
15-X300-Gong PDC vorn
16-X300-Schalter PDC
17-X300-
18-X300-
19-X300-Sicherungskasten Motorraum F12
20-X300-
21-X300-
22-X300-
23-X300-
24-X300-
25-X300-
26-X300-Gong PDC hinten
Please someonen confirm this laid out. I am not sure about pin 13 y 19.
Thanks
Javier
29.03.2007, 18:56
Fahrzeug: E32 735iA Bj.05/89
hello javier,
i confirm this information.
to switch from 8 to 4 Sensors, put 12 Volt on Pin 1
8 Sensors = 0 Volt
4 Sensors = 12 Volt
greetings Joe735
22.10.2009, 21:46
mr.
Fahrzeug: E32 735i
Hello,
Since I saw this thread i wanted to ask if someone has the electrical Scheme of the PDC system, because i've "implanted" the whole system into my car, with all of the 8 sensors, but the problem is that the button doesn't operate when i'm using the headlights.
22.10.2009, 22:12
7er-Fan
Fahrzeug: 318i (Bj. 12/01)
Gibts das auch in deutsch????
gibts sowas auch in deutsch???
Hello,
does this Thread also exists in german?
Thanks a lot.
Greeting
pegasusqmb
