02.08.2010, 15:56
Fahrzeug: E65 750i (7/2006)
Zitat von elDudereeno
The electric throttle needs a bulb which is located in the speedometer of the E32.
But you can also use an external lamp. (About 2 watts)
02.08.2010, 19:14
is pending...
Fahrzeug: E30 350i 6-Gang M70 05´92;
Yes, you don´t need the speedo or dashboard.
Just a 2watt bulb.
What you realy need is the Speedsignal!
If you don´t have it you´ll only get half power and that is boring...
02.08.2010, 19:24
#13
thanks, 2 watt is also new info for me.
2 watt bulb on which Pin/line/wire exactly?
Steckerbelegung Kombi
02.08.2010, 19:39
#15
checked to quick and missed that
thanks, Johan
02.08.2010, 19:40
#16
is pending...
It is x502 pin 16 and 17.
I have both wires on the bulb.
It´s looking like that:
12volt Batt. ===> 7.5amp Fuse ===> 2Watt bulb ==> Both wires on x502 pin 16&17
Both wires go to EML and during the Test EML will connect them to 0 Volt/Ground/Chassis ...
(i´m writing too slow..... )
Geändert von Grimmjar (02.08.2010 um 19:55 Uhr).
02.08.2010, 21:28
#17
Fahrzeug: skoda superb II
Thx. Where does the ecu gets its speedsignal? I thought you could change the ecu to "manual gearbox mode" and that then it was ok..
Ps I bought the engine and other parts. The vendor is now parting the e32 out and 'll let me now when I can pick up my new engine..
Greetz,
K
02.08.2010, 23:57
#18
is pending...
Speedsignal comes from the rear axle differential.
But there is a cheap way around this.
btw.: what rear axle do you have?
03.08.2010, 10:16
#19
Rear axle is from volvo 245 turbo (1031 axle), can normally cope with 500NM.
03.08.2010, 10:46
#20
So I ask the vendor if he can give me the speedsensor on the reardiff as well?
Greetz,
Kris
