Alt 01.08.2010, 22:06   #1
transeurope
Fahrzeug: skoda superb II
Idee m70 umbau nicht bmw
Hello
I'm buying a m70 from a 94 e32. What do I certainly need to buy with it to let it run in a non bmw car?
I think I need:
Engine
3 ecu's and loom
2 lmm's and maybe also the airboxes
bellhousing of autobox (I wanna use a tremec t56 6 speed)
And also the device for the electric throttle? Is it located near the throttle pedal?
Anything else?
Cheers & thanx in advance. Sorry for the english but my "Deutsch" is even worse ;-)
ps Am I right this engine is still the m70 version with boostfriendly CR?
transeurope ist offline   Antwort Mit Zitat antworten
Alt 01.08.2010, 22:44   #2
elDudereeno
Benutzerbild von elDudereeno
Fahrzeug: E65 750i (7/2006)
Yes, the throttle position sensor is located near the pedal.
I think, thats what you need.
Of course, all the other sensors too.
Cylinder identifictaion, engine speed signal, water temperature and air temperature (every sensor twice).
I would also use the original alternator and if needed, the air conditioning compressor and the power-steering pump.
Maybe also the oxygen sensors.
Part of the loom is a relay box which you should also use.
The electric throttle needs a bulb which is located in the speedometer of the E32.
But you can also use an external lamp. (About 2 watts)
The ecus need a speed signal which they get from the speedometer.
Actually it comes from the differntial (9 pulses per rotation) but the speedometer treats the signal.
There exists a BMW 6 gear box from the BMW 850 which fits to the M70.
(Right now, there are some new ones on ebay)
In which car you want to attach the M70?
And do you wanna turbo charge it?
elDudereeno ist offline   Antwort Mit Zitat antworten
Alt 02.08.2010, 14:56   #3
elDudereeno
Alt 02.08.2010, 18:14   #4
Grimmjar
is pending...
Benutzerbild von Grimmjar
Fahrzeug: E30 350i 6-Gang M70 05´92;
Yes, you don´t need the speedo or dashboard.
Just a 2watt bulb.
What you realy need is the Speedsignal!
If you don´t have it you´ll only get half power and that is boring...
Firing Order
1-7-5-11-3-9-6-12-2-8-4-10
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) powered by: Wizard of NOS
Grimmjar ist offline   Antwort Mit Zitat antworten
Alt 02.08.2010, 18:24   #5
thanks, 2 watt is also new info for me.
2 watt bulb on which Pin/line/wire exactly?
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Steckerbelegung Kombi
Alt 02.08.2010, 18:40   #6
Grimmjar
is pending...
It is x502 pin 16 and 17.
I have both wires on the bulb.
It´s looking like that:
12volt Batt. ===> 7.5amp Fuse ===> 2Watt bulb ==> Both wires on x502 pin 16&17
Both wires go to EML and during the Test EML will connect them to 0 Volt/Ground/Chassis ...
(i´m writing too slow..... )
Geändert von Grimmjar (02.08.2010 um 18:55 Uhr).
Alt 02.08.2010, 20:28   #7
transeurope
Thx. Where does the ecu gets its speedsignal? I thought you could change the ecu to "manual gearbox mode" and that then it was ok..
Ps I bought the engine and other parts. The vendor is now parting the e32 out and 'll let me now when I can pick up my new engine..
Greetz,
K
Alt 02.08.2010, 22:57   #8
Grimmjar
is pending...
Speedsignal comes from the rear axle differential.
But there is a cheap way around this.
btw.: what rear axle do you have?
Alt 02.08.2010, 18:29   #9
Johan735
Benutzerbild von Johan735
Fahrzeug: E32-750i | E39-525i | F10-523i
Seriously? It's in the link you posted!
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.e32-schrauber.de/bmw/date...egung-x502.pdf -->x502 pin 16 and 17: "Kontrollampe" "EML"
Johan735 ist offline   Antwort Mit Zitat antworten
Alt 02.08.2010, 18:39   #10
checked to quick and missed that
thanks, Johan
Gas-Antrieb: umbau dk750il BMW 7er, Modell E32 2 13.02.2008 20:03
Karosserie: Umbau Außenspiegel auf schnittige nicht diese Klötze Scharly BMW 7er, Modell E38 12 22.09.2004 15:54
Umbau MK1 auf MK3 nicht mehr problematisch! cesa1882 BMW 7er, Modell E38 14 27.02.2004 08:23
Radio Umbau mit ISO Stecker klappt nicht DieterThai BMW 7er, Modell E32 20 30.08.2003 14:13
Umbau von MK1 auf Mk2 Porky2412 BMW 7er, Modell E38 2 29.01.2003 21:11
Alle Zeitangaben in WEZ +1. Es ist jetzt 14:42 Uhr.
