Alt 11.03.2004, 05:23   #2
nach 4 Jahren koennte die Batterie schon am Sterben sein. Habe Dir hier mal aus roadfly was kopiert:
Find a digital multimeter and stick the probe into the cigarette lighter socket in the center console.
The following are the detail figures I use for my own evaluation:
With key out of ignition switch, should see 12.4V or above. 12.0 V is getting low.
With key inserted and turned to position 2 (don't start car), should see 12.0V or more. 11.6V would be too low.
Crank car, catch the lowest voltage reading during that couple of seconds. Should see 10.0V or above. 9.5V would be marginal.
The above just consider the health of battery itself.
Car running at 1500 RPM or more, should see 13.7 to 14.3V, 13.6V or below means the charging system is weak.
Patrick C 88 750 130K
Alle Zeitangaben in WEZ +1. Es ist jetzt 15:31 Uhr.
