Alt 23.06.2005, 20:49   #1
Janos 728
Benutzerbild von Janos 728
Fahrzeug: e46 320d Touring FL
only with BMW Diagnostic Tool. (GT-1, DIS-plus)
Janos
Janos 728 ist offline   Antwort Mit Zitat antworten
Alt 23.06.2005, 20:56   #2
EmilC
Fahrzeug: bmw 735I (E32) 92, 730IA (E38) 94, 735li (E66) 95
what is it and where can i get it from?
EmilC ist offline   Antwort Mit Zitat antworten
Alt 24.06.2005, 08:32   #3
Franz3250
Taxifahrer
Benutzerbild von Franz3250
Fahrzeug: S211
Ask your local BMW-Dealer. He has the technical equipment.
Greets
Franz
(Murphy)
Alt 24.06.2005, 08:50   #4
WSE
Fahrzeug: E38 730d
You could buy a GT-1 from Central Lettershop for 17 500$...
WSE
WSE ist offline   Antwort Mit Zitat antworten
Alt 24.06.2005, 09:49   #5
EmilC
thanks all...
Alt 24.06.2005, 16:07   #6
francozero
Benutzerbild von francozero
Fahrzeug: BMW 730iAL (E38)
You can change the language in every BMW... I have mine set to english (as dutch is not an option).
I'm affraid i forgot the right sequence, but it's simply done with the 2 buttons in the tacho and you don't need any extra tools to do it.
If i'm not mistaken, you have to turn the key in position 1 (radio, no ignition) and keep the right button pushed until the display passes "CC OK". Then walk through the menu with the left button until you see "Sprache". Select this option by pressing the right button again, and use the left button to look for "English".
I could be wrong about the position of the ignition-key, tho... Try it in position 1 (radio, no ignition), and if that doesn't work, try position 2 (all power on without crankin' the engine).
Anyway, should you have any doubts about this, you can always find help at any BMW-dealer for free. Also help with your BC, phone, etc... shouldn't cost you anything at the dealer...
franco
francozero ist offline   Antwort Mit Zitat antworten
Oel-Analyse Erich BMW 7er, allgemein 2 09.02.2004 19:51
Like to change thelanquage to the voice control?! moriz202 BMW 7er, Modell E65/E66 11 17.01.2004 14:49
Can you change speakers when you have DSP? B12 5.7 Lang BMW 7er, Modell E38 3 28.04.2003 07:13
Alle Zeitangaben in WEZ +1. Es ist jetzt 12:27 Uhr.
