Batterie abklemmen fuer einige Minuten und GM raus und dann wieder rein. und Batterie wieder dran. Grundmodul lernt nun, dass es ein Schiedach hat.
"I would venture to guess either the general module or the relay module, first
would disconnect the battery and remove the general module and wait a few minutes and reconnect and see if it still does it... Also there's a service bulletin out that says any time you remove the general module the battery must be disconnected first and it must be plugged back in before reconnecting battery...."
Aus Bimmer.info
Dann gibt es eine Anleitung im Bentley Reparaturbuch, hab Dir das mal kopiert aus dem US Forum
to sync sunroof to motor gear there is a set procedure in Bentley. Essentially you use a hex tool to close the sunroof manually, then remove the motor and continue to use the hex tool to turn the plastic (my case, blue) gear until a point on the gear lines up with a mark on the metal housing. The worm gear that drives the cables that move the sunroof skips so you may have to re-sync again after two weeks. In my case I inserted some 0.020 inch metal shims to push the cable closer to the worm gears, not too many miles ago.
