14.04.2008, 20:32
750i powered by ROTTALER2
You´ve near the Batterie a very strong Fuse.
Check this of broken parts.
look in this Thread, the answer # 18 and # 19 has the pictures, wich
explain this Fuse.
http://www.7-forum.com/forum/5/motor-geht-59857-2.html
best regards
Peter
14.04.2008, 20:37
Fahrzeug: E32 750 '91
Zitat von peter becker
Hi Peter,
I'll check the fuse. Now the car is at the supermarket where I left him when I was shoping for dinner
This happened last week then after hours rest or so the car started perfectly.
I did know that my E32 had an soul but this fail is quite devilish
14.04.2008, 20:44
BastardOperatorFromHell
Zitat von Erlingur
Hi Peter,
hi!
maybe the starter-relays or the starter hangs. i had the same problems with an VW Golf 3.
best regards
Thorsten
14.04.2008, 20:45
mmmh, if this fuse is in good condition, my next guess is the Starterrelay
Best regards
Peter
14.04.2008, 20:47
Best regards
Peter
Can you tell me where the Starterrealay is located
Regards from Iceland
14.04.2008, 21:06
yes, the Starterrelais is the K1 in the fusebox, i can´t find the picture
this moment,but i am searching.
and bingo...... look here
http://bmwe32.masscom.net/johan/e_box/fuse_box.html
Best regards
Peter
Geändert von peter becker (14.04.2008 um 21:17 Uhr).
14.04.2008, 21:44
nur ölich fröhlich..
I get all the lights on the dashboard when I switch the car on but when I try to start I only hear a litle click sound but the starter wont start.
mal kurz auf deutsch reingefragt - das hört sich nach genau demselben prob an,was ich seit kurzem in unregelmäßigen Abständen haben - wagen klickt,strom lima usw alles top,aber kein starten.nach 2-10 mal schlüsseldrehen startet er dann.Ist das nicht zwingend der Anlasser?
die letzte woche war der fehler allerdings komplett weg?
gruß Marco
@erlingur,xcuse the german,it seems that i have the same problem with my bmw
14.04.2008, 21:46
Now I just have to walk back to the supermarket and see if the M70 babe will start for me.
I'll post the solution here if I find it.
Best regards from Iceland,
Erlingur G
E32 M70
E38 M73
14.04.2008, 22:40
Fahrzeug: E32-750iL Highline (PD 04.91/EZ 7/91), Lanica Thema Turbo 16VLS SW (94), DB 280 S (W116), Opel Admiral A 2,6 (64), Opel Blitz (73)
Hello to Iceland!
To me it sounds like the so-called "Magnetschalter" of the starter is defective. Pretty common starter fault, whatever car you drive. Unfortunately I don't know the English or Icelandish translation for "Magnetschalter", but the web should have it, somewhere. My suggestion would be to replace the starter as such. Up il then, numerous tries will lead to success, at least that's the way it works for almost two years with my W116 Mercedes, a bit ennoying at times, still it always has started, sooner or later.
Good luck
Lutz
