18.12.2008, 16:07
Fahrzeug: E38 740iA -99
E38 Webasto retrofit?
Hello,
Sorry i speak only (bad) English but have to ask if someone can help me.
I have 740iA 1999 and I'm going to install Webasto Thermotop Z/C. Webasto is from 2001 e39 so it is bus controlled, no problem at electronics. But I'm curious about how it's mounted in e38. If i understand right, it has same "carrier/hinge" that in e39, whatever that name is, but how's car side? Is car body "carrier/hinge" welded or bolted in car. I have troubles of finding that car side "carrier/hinge". It would be great if someone have pics at stock webasto installation in e38. And also, how waterlines are routed to engine bay in stock installation?
Thanks and hope someone understand me.
18.12.2008, 16:18
As far as i know, the position on an E38 is under the front left fender (Kotflügel). The position in an E39 is behind the front right headlight.
BMW hat das langersehnte Ziel von Alchemisten erreicht: Aus Eisen (bzw. Stahl) Gold herzustellen. E39/E38 und E46 sind der Beweis: Gold, Gold wohin man schaut - OPELGOLD  .
18.12.2008, 16:32
In both e38&e39 it's under front left fender as you say, i know it because i repair these webasto controller cards and have removed several webastos from e39 but i have seen none e38 with webasto, only know that it is in same place but is mounting "carrier" welded or bolted in e38? Last option would be to make my own mountings for e38.
18.12.2008, 18:08
Fahrzeug: E38 740i 03/2001
...maybe you need No 13 ?!?
Warum sachlich, wenns auch persönlich geht...
18.12.2008, 18:56
I have already No.13 but looks like i need No.2 but it doesn't have part number? Does it come with No.13 if i buy it from dealer? That is the main problem, i don't find no.2 anywhere.
18.12.2008, 19:04
happy to search for you... No 5
18.12.2008, 19:10
Thanks!! I didn't realize it was in different location than heater itself. But have to order that from dealer.
