Alt 31.10.2009, 17:27   #1
Erlingur,
was that a new starter or a used one? If used, it could also be 'kaputt'. Early motor starters had almost all the inner parts made of plastic, we disassembled my spare starter and that looked like this one
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) FIXES - STARTER MOTOR
You can remanufacture it, you can also use a starter from Bosch for Mercedes Benz if the type is the same, the only difference is the number of teeth on the drive, M70 starter motor has 9 teeth.
the next point to check is the cable from starter, it could look like my cable from the alternator to the B+ pole
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) FIXES - ELECTRICAL POWER SYSTEM
Alt 31.10.2009, 17:54   #2
Erlingur
Fahrzeug: E32 750 '91
Hello Erich,
I'll have to check my starter cable.
That could be the reason for what seems to be bad contact/lack of power and electrical smell and smoke :(
The starter is brand new (but an aftermerket type) so I assume that the cable is more likely.
I'm planing to get to this repairs next weekend, so then problably I'll then continue with the limp mode problem.
I have been reading through the limp mode and EML repairs you have posted (can understand some german)
Does the bulp in the dash board have to glow???
If the EML light does not come on shall I fix the dash board first?
MHG
E
Erlingur ist offline   Antwort Mit Zitat antworten
Alt 31.10.2009, 18:04   #3
amnat
† August 2024
Benutzerbild von amnat
Super interesting pictures as usual, by Erich; work on the 750 seems to be a sweaty job, but this is surely not a problem in Iceland.
Alt 31.10.2009, 22:35   #4
I have been reading through the limp mode and EML repairs you have posted (can understand some german) Does the bulp in the dash board have to glow???If the EML light does not come on shall I fix the dash board first?
MHG E
It MUST be on for 2-3 seconds when you start the engine and then disappear. If not, limpmode
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) EML bulbs
Interner Link) http://www.7-forum.com/forum/24/eml-...ten-41084.html
Elektrik: starter spinnt.. darkonaz BMW 7er, Modell E38 11 05.10.2006 21:09
Kennt Ihr eigentlich die Heavy-Duty-Lager von Meyle? MR77 BMW 7er, Modell E32 16 12.02.2006 13:34
Motorraum: clear flood mode.... Erich BMW 7er, Modell E32 0 30.09.2005 07:41
Starter defekt ? Der Ingenieur BMW 7er, Modell E32 10 07.11.2003 21:16
Starter? DaMartin BMW 7er, Modell E32 1 13.12.2002 23:07
Alle Zeitangaben in WEZ +1. Es ist jetzt 05:53 Uhr.
