Alt 06.08.2010, 18:45   #4
memyselfundich
Langstrecken Gleiter
do you have access to a "INPA" enpowered laptop?
if yes, then you could try the "Unruhemessung" Not sure how it´s called in english - It´s the Measurement you can start to see which cylinder is running not a smooth as the others. The Coil´s *can* bei DOA, are they aftermarket or OEM Bmw?
Switching of the After cat sensors is usually not needed - but the BEFORE cat sensors are quite important.
While you are already busy spending money - switch the "LMM" Air Mass measurement things in front of the throttlevalve - which you can also switch out while you are at it Then change the Valve cover gaskets, and your engine will pur as new
Vanos im 735 740? Rainer H BMW 7er, Modell E38 8 02.12.2011 21:24
General question + noise -> in the trunk Maarten730 BMW 7er, Modell E32 7 05.04.2009 18:41
Motorraum: Vanos ? andromedar2000 BMW 7er, Modell E38 6 15.04.2007 22:37
VANOS o. Doppel-VANOS EXPERTEN gesucht JB740 BMW 7er, Modell E38 19 01.04.2006 20:57
730d turbo(?) noise and lack of power Rik Gruwez BMW 7er, Modell E38 3 11.01.2003 12:31
Alle Zeitangaben in WEZ +1. Es ist jetzt 18:41 Uhr.
