Alt 08.08.2010, 15:18   #8
Glacier
Benutzerbild von Glacier
Fahrzeug: E38 - 740i (02/2000)
Yes, you are probably right.
The air intake manifold gaskets were done at the same time as the PCV valve, and I checked for vacuum leaks by spraying brake cleaner all around the engine to see if there was a change in the idle........nothing.
When I tried to reset the adaptions there was a message saying "Module not responding". Even so, I have driven about 300 miles since the re-timing so I would have thought the DME would have learned the adaptions by now.
I wonder if there is a burnt valve or something?
Oh well, I'll keep trying to find what's wrong and will report back if I find anything.
Many thanks again for all your suggestions.
Glacier ist offline   Antwort Mit Zitat antworten
Vanos im 735 740? Rainer H BMW 7er, Modell E38 8 02.12.2011 21:24
General question + noise -> in the trunk Maarten730 BMW 7er, Modell E32 7 05.04.2009 18:41
Motorraum: Vanos ? andromedar2000 BMW 7er, Modell E38 6 15.04.2007 22:37
VANOS o. Doppel-VANOS EXPERTEN gesucht JB740 BMW 7er, Modell E38 19 01.04.2006 20:57
730d turbo(?) noise and lack of power Rik Gruwez BMW 7er, Modell E38 3 11.01.2003 12:31
Alle Zeitangaben in WEZ +1. Es ist jetzt 11:32 Uhr.
